Author Topic: New update for C3D 2011 here are the fixes  (Read 3024 times)
sourdough
« on: July 08, 2011, 10:15:42 AM »
Hi All just found this.... it may be worth it or ??
Primary Issues Resolved by This Update
The following issues have been fixed:
Alignments
When using multisegments, the station range of a surface profile is now the same as the station range of the alignment.
API
StationOffsetElevationToBaseline no longer returns inconsistent values when queried multiple times for the same object.
Alignment.StationOffset() no longer returns inconsistent values.
Corridor Design
Corridor feature lines now connect when the center alignment and the offset alignment have different station ranges.
Corridor Volumes
When generating materials automatically by sample line group, canceling the dialog no longer causes AutoCAD Civil 3D to close unexpectedly.
Feature Lines
An unexpected error that occurs when editing a feature line has been resolved.
General/Other
A delay displaying contours on when first opening a drawing has been resolved.
If the ApplyTransform check box on the Transformation tab of drawing settings in not selected, AutoCAD Civil 3D no longer sets the reference point on the AutoCAD Geo Data object.
AutoCAD Civil 3D no longer stops responding after the installation of Autodesk Raster Design.
An unexpected error that occurs when opening a drawing using the Civil 3D as AutoCAD profile has been resolved.
An unexpected error that occurs when closing a drawing using the Civil 3D as AutoCAD profile has been resolved.
Hydrology and Hydraulics
Importing a localized DXF as a background image in Storm Sewers no longer generates an error.
Pipe diameter is properly matched when importing a LandXML file into Autodesk Storm and Sanitary Analysis.
Performance
Memory performance has been improved when repeatedly opening drawings with Alignments.
Cogo Point, Parcel, Grading, Lot Line, Alignment, Feature Line, and Survey Figure objects should now display proxy graphics and bounding boxes in accordance with the AutoCAD PROXYGRAPHICS and PROXYSHOW variables.
Moving tables no longer causes AutoCAD Civil 3D to stop responding.
Performance when triangulating surfaces in 64bit has been improved.
Hardware Acceleration no longer causes model space to flicker, a white viewcube background, or AutoCAD Civil 3D to stop responding.
Pipes
When reopening a drawing with referenced pipes in Section Views, the referenced pipes now show in section view and network section labels no longer disappear from the drawing.
Pipe Style elements properly honor color as defined in the style.
Structures with insertion points that are not centered are now correctly placed in the drawing.
Drawing audit now repairs .NET pipe rules.
Points
When selecting all points, then editing the column width, AutoCAD Civil 3D no longer stops responding.
Importing points using custom file import no longer causes an unexpected close.
Toggling Toolspace status no longer causes an error after exiting.
Changes to the priority order of Description Key Sets are now retained as expected.
An unexpected error that occurs when adding points to a dynamic points table when there are two or more tables has been resolved.
Profile View
OSNAP behavior is now supported with multiple split profile views.
Project Management
When exiting AutoCAD Civil 3D while logged into Autodesk Vault, a message that the AutoCAD Application has stopped working is no longer generated.
Corridors with offset alignments are now displayed as expected when XREFed.
Importing an AutoCAD Civil 3D project into Autodesk Vault no longer causes an unexpected close.
Surface
Surface Style elements properly honor plot settings as defined in the style.
Survey
The order of observations has been corrected to allow proper adjustment of north azimuth surveys.
In Observation Editor, if the default point number is changed, two new points are no longer created.
In Observation Editor, descriptions are now saved when entering new observations.
Importing survey points using the CAiCE migration tool and CAiCE point format no longer causes AutoCAD Civil 3D to close unexpectedly.
When right-clicking the traverse name in the Traverse Editor panorama and selecting Traverse Analysis, AutoCAD Civil 3D no longer stops responding.
User Interface
Toolbox content in the Panorama window can now be saved.
When rolling over an MPOLYGON object the tooltip no longer causes AutoCAD Civil 3D to close unexpectedly.
LDC 2009/C3D 2010/C3D 2011/C3D 2016
Win 10 64bit
BlackBox
Re: New update for C3D 2011 here are the fixes
« Reply #1 on: July 08, 2011, 11:22:44 AM »
Thanks for sharing.
Cheers! :beer:
« Reply #2 on: July 08, 2011, 11:30:11 AM »
there is also a HOTFIX for the SSA tools as well:
Autodesk Storm and Sanitary Analysis 2012 Hotfix (localized Civil 3D and Map 3D versions Only)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17218626&linkID=9240698
