Author Topic: Autocad 2012 - How do you like the new ARRAY?  (Read 3186 times)
JCTER
« on: May 16, 2011, 03:25:27 PM »
So to recap, in 2012, the ARRAY tool went 100% command-line.  It also is more 'dynamic', allowing you to use on-the-fly mouse input to enter the values for the array as it asks, showing you a preview of the array as you go, and creates an 'array object' that you can edit with grips or via it's properties, after the fact.  This comes with pros/cons, of course, and I'm curious how you feel about it.
JCTER
Re: Autocad 2012 - How do you like the new ARRAY?
« Reply #1 on: May 16, 2011, 03:28:14 PM »
I voted that I really like the tool, but honestly I find that the vast majority of the time, I don't want a single array object.  It seems like the vast majority of the time I use ARRAY; the final product is not a simple, ideal, perfect array of objects, and that I will always have to tweak, move, rotate, or alter at least ONE of the objects in the array.
This means I have to *shudder* EXPLODE the array into it's baser objects, just so I can alter one or more of the individual entities.
It's a really great tool, I love every bit of it.  It's elegant, pretty, and no more pointless GUI - it's just not practical to my uses, I guess.
I also am still trying to get out of my old keyboard habits.  I'm having trouble getting the muscle memory down still.  While annoying, I don't hold that against the command itself, as that'll pass.
« Reply #2 on: May 16, 2011, 11:18:49 PM »
Some of us still in the dark ages. :-(
2006 here.
LE3
« Reply #3 on: May 16, 2011, 11:30:10 PM »
not using autocad at this time...
that 'new' tool looks very similar to the move\copy parallel command that was available in intergraph microstation 4.0, btw (that i was an user back on 1994)
 :-P
« Last Edit: May 16, 2011, 11:41:51 PM by LE »
Daniel J. Ellis
« Reply #4 on: May 17, 2011, 03:07:42 AM »
I've not installed 2012 yet to know for myself but what I've read suggests those changes are all possible *within* the array object (I think using grip edits)
dJE
dJE
JCTER
« Reply #5 on: May 17, 2011, 09:19:28 AM »
dJE
Unfortunately not.  The change I'm talking about is being able to move objects after they are arrayed.  Say I want to array one column 6 times in a polar array, like a gazebo columns, or something.  But I need to move one column inside a bit for some reason, so that it were at a different distance from center, than the others.  Can't do it unless you explode the array.  The only grip edit I can do is to change the distance between objects, or the radius of the entire array.
deegeecees
« Reply #6 on: May 17, 2011, 10:31:02 AM »
2006 here.
Same here.
2009  :-P
JCTER
« Reply #7 on: May 17, 2011, 10:33:47 AM »
lol.
Thanks guys.  I'll bump the poll up again in a couple years and see what I get.  :-D
alanjt
  • Standby for witty remark...
« Reply #8 on: May 17, 2011, 11:37:13 AM »
lol.
Dropbox
JCTER
« Reply #9 on: May 17, 2011, 11:49:14 AM »
