Author Topic: slow grip selection/response  (Read 4213 times)
CHulse
« on: May 12, 2011, 05:26:55 PM »
Has anyone else found selecting grips (on plines, blocks, etc) to be painfully slow? There is a hesitation when you select or unselect.
I am using C3D 2011 on a windows 7 x64 machine. 8 gb ram, not a slow machine...
Any thoughts on improving this? It seems like it needs to analyze the entire dwg ever time you select a grip...
thanks
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
Re: slow grip selection/response
« Reply #1 on: May 12, 2011, 05:45:26 PM »
how many grips within objects do you have enabled through Options>>Selection?
and or
how many people are standing behind you watching you work?
CHulse
« Reply #2 on: May 12, 2011, 08:38:50 PM »
nobody behind me :)
Thanks for the suggestion. I played with the selection settings, but no apparent improvement. The hesitation also seems to happen even if I select nothing (drag an empty selection box) - there is a lag before the cursor catches up again after...
Cary Hulse
« Reply #3 on: May 12, 2011, 08:40:30 PM »
nobody behind me :)
how bloated is this file?
may I see a copy?  (FTP data upon request)  *all non disclosure agreements implied*
« Reply #4 on: May 12, 2011, 08:47:59 PM »
Also try turning the Ribbon Off or the context switching off or both...
RIBBONCLOSE
RIBBON
and what is the setting for
RIBBONCONTEXTSELECT?
try using ZERO 0
CHulse
« Reply #5 on: May 12, 2011, 08:48:31 PM »
It seems to be every file, not just this one. That's why I thought it might have been a setting of some kind.
Cary Hulse
CHulse
« Reply #6 on: May 12, 2011, 08:49:22 PM »
The ribbon is already off (I prefer old school...)
Cary Hulse
sinc
« Reply #7 on: May 12, 2011, 08:59:50 PM »
Do you have the Properties window open (maybe docked)?
CHulse
« Reply #8 on: May 12, 2011, 09:14:08 PM »
We have a winner!!  :-D
Yes, closed the properties box and all is well. Thanks - I have always left it up and never thought it would make such a difference.
Thank you!!!
Thanks Michael for your suggestions also, much appreciated.
Cary Hulse
