Author Topic: Prevent network structures from being automatically rotated (Civil 3D)  (Read 6975 times)
alanjt
  • Standby for witty remark...
Is it possible to prevent network structures from coming in rotated? If I want them rotated, I'd rather do it myself.
Dropbox
which structures are you talking about?
round ones
eccentric ones
rectalinear ones
help me help you
alanjt
round ones
eccentric ones
rectalinear ones
help me help you
Round ones. Manhole lids to be exact. Sorry for the unintentional ambiguity, I didn't think it mattered.
Dropbox
OK, except the 'lid' is being rotated with the structure I believe it isn't controlled independently.
During Pipe Network creation, the answer will be NO
When placing 'Structures Only' still NO only they come in @ zero rotation
A process one might employ:
Draw the network
Select one structure>>Rt-click  'Select Similar'>>Delete
Then place structures only as part of the network they should insert at zero for you then.
round ones
eccentric ones
rectalinear ones
help me help you
Shape of structure really wasn't important, only wanted to keep you busy while I looked into the answer.   ;-)
alanjt
Draw the network
Ehh, screw it. It's not that big of a deal, it's just annoying when the S or D for a storm/sewer manhole is rotated. If it was some simple setting, I'd go with it. Thanks Michael.
round ones
eccentric ones
rectalinear ones
help me help you
LoL
Dropbox
You can also set the rotation for all structures (or just selected ones) at once after they are created if you like, using the Pipe Network Vista editor.
alanjt
Ahh, it's rotating them based on the UCS. Even when you edit them in the vista, your angle has to account for a rotated UCS.
(defun c:STZ (/ a ss i)
  ;; Set AECC Pipe Network Structure to UCS X Direction
  ;; Alan J. Thompson, 05.11.11
  (setq a (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 (trans '(0. 0. 1.) 1 0 T) T)))
  (if (setq ss (ssget "_:L" '((0 . "AECC_STRUCTURE"))))
      (vlax-put-property (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'Rotation a)
Dropbox
Uh why are you working in a rotated UCS?
alanjt
I always set my UCS to match my view. I want to be able to place text, etc. and it look correct. C3D labels will do this, but not mtext/mleaders.
Dropbox
alanjt
Please correct me if I'm doing something wrong/stupid.
Dropbox
The issue with UCS set to matching anything other than world...is the potential for point data to be extracted or created and cause havoc.  ( I know it won't ever happen to *YOU* because you have some how managed to work around this or simply accept it as a risk. And *YOU* knoe who you are.    ;-))
It would be suggested that one place those NON C3D labels through the Paperspace viewport.
They will then be placed correctly to the View's UCS only you will not need to create or manage it.
This leaves modelspace always at world.
Or switch some of those dumb MTEXT notes over to General Note Labels; my guess is some of them fall into the category of Typical Notes and  find their way onto your plans regularly.
