Author Topic: Autolisp file formatting utility  (Read 4857 times)
kenkrupa
« on: April 14, 2011, 07:31:05 PM »
I used to have one - a DOS .exe file - that would reformat a .lsp file that was all scrambled up (no indents, etc.) to make it readable. I lost it in a computer change and haven't been able to find it anywhere.  It might have been lispfix.exe, or something like that. Can anyone hook me up with this?
Re: Autolisp file formatting utility
« Reply #1 on: April 14, 2011, 07:49:31 PM »
Why not use the code formatting options in the VLIDE?
kenkrupa
« Reply #2 on: April 14, 2011, 08:06:21 PM »
Never thought of that since I don't use VLIDE. But I gave it a try. I still like the results my old tool gave me, even after messing with the settings, but this will do well enough (unless someone can still hook me up with that old one).  Thanks Lee.
« Reply #3 on: April 14, 2011, 08:07:58 PM »
20 years old.
Haven't used it for 10 or so
Try this
« Reply #4 on: April 14, 2011, 08:19:59 PM »
That is an interesting (and quite amusing) read! Its great to see the solutions that are used when VLISP isn't available.
Thanks Kerry :-)
kenkrupa
« Reply #5 on: April 14, 2011, 08:23:45 PM »
I don't know Kerry - this one seems pretty scary to me:
 Usage:  (pprint expression stream)
;;; PPRINT - Prettyprint a LISP expression, indenting according to the
;;; structure of the expression and user modifiable parameters.
Wha?!?!? My old one worked on a file name in a DOS window. Even I could understand that.
LE3
« Reply #6 on: April 14, 2011, 08:39:27 PM »
maybe you are talking about LB.EXE (lisp beautifier) ?
« Reply #7 on: April 14, 2011, 08:51:36 PM »
I just tried LB
Won't load/run in x64  :cry:
xiaxiang
« Reply #8 on: April 14, 2011, 09:34:48 PM »
Hi
    I found lb.exe and posted it.Even though I don't know the usage of it .
And more info might help you.
http://www.archx.at/archX/AutodeskSdk
http://autocad.xarch.at/lsp_tools/
Just using google to search "lisp beautifier lb.exe".
« Last Edit: April 14, 2011, 10:02:20 PM by xiaxiang »
xiaxiang
« Reply #9 on: April 14, 2011, 09:57:01 PM »
The usage of lb.exe:
dos prompt: lb 1.lsp 2.lsp
It works well!
kenkrupa
« Reply #10 on: April 15, 2011, 01:24:14 PM »
It works well!
Not in 64 bit. Thanks anyway. I guess VLIDE will serve well enough.
« Reply #11 on: April 15, 2011, 01:29:31 PM »
xiaxiang
« Reply #12 on: April 17, 2011, 06:54:27 AM »
pBe
« Reply #13 on: April 17, 2011, 07:21:08 AM »
