Author Topic: Can a file be moved using LISP...  (Read 6214 times)
A_LOTA_NOTA
« on: April 12, 2011, 04:33:46 PM »
When a drawing has been revised we create a PDF and move the old PDF to a "VOID" folder. So for example when 301s1r1.pdf is created 301s1r0.pdf would need to be moved. Could lisp be used to accomplish the moving of the old file?
Re: Can a file be moved using LISP...
« Reply #1 on: April 12, 2011, 04:50:26 PM »
Maybe something like this?
(defun LM:MoveFile ( file dest / fso result ) (vl-load-com)
    (and
      (setq file (findfile file))
      (setq dest (strcat (vl-string-right-trim "\\" (vl-string-translate "/" "\\" dest)) "\\"))
      (or (vl-file-directory-p dest) (vl-mkdir dest))
      (setq fso  (vlax-create-object "Scripting.FileSystemObject"))
    (setq result (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-invoke (list fso 'MoveFile file dest)))))
  (if fso (vlax-release-object  fso))
  result
e.g.
(LM:MoveFile "C:\\MyFile.txt" "C:\\MyFolder\\")
MyFolder is created if non-existent.
« Last Edit: April 12, 2011, 04:54:40 PM by Lee Mac »
alanjt
  • Standby for witty remark...
« Reply #2 on: April 12, 2011, 04:52:36 PM »
MoveFile
Bah! I tried Move, it didn't work and I went on with my business.
Dropbox
LE3
« Reply #3 on: April 12, 2011, 04:58:38 PM »
or the old fashion way (of DOS) via command SHELL
Command: SH
OS Command: MOVE E:\\TEST.TXT E:\\TEMP
« Reply #4 on: April 12, 2011, 05:01:06 PM »
MoveFile
The 'Move' method may also be used, but it requires different parameters:
(defun LM:MoveFile2 ( file dest / fso fob result ) (vl-load-com)
    (and
      (setq fob  (vlax-invoke fso 'getfile file))
    (setq result (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-invoke (list fob 'Move dest)))))
  (if fob (vlax-release-object  fob))
  result
« Reply #5 on: April 12, 2011, 05:12:40 PM »
Or for moving files and folders:
(defun LM:Move ( target dest / fso fob result ) (vl-load-com)
    (and
      (setq target (findfile target))
      (setq fob    (vlax-invoke fso (if (vl-file-directory-p target) 'getfolder 'getfile) target))
  result
(LM:Move "C:\\MyFile.txt" "C:\\MyFolder\\")
(LM:Move "C:\\NewFolder" "C:\\MyFolder\\")
LE3
« Reply #6 on: April 12, 2011, 05:22:12 PM »
something so easy like this:
(setq OriginalNamePath "E:\\TEST.TXT")
(setq NewNamePath "E:\\TEMP")
;; or change the name too
(setq NewNamePath "E:\\TEMP\\TEST1.TXT")
(defun MoveMyFile(OriginalNamePath NewNamePath)
    (command "SHELL" (strcat "MOVE " OriginalNamePath " " NewNamePath)))
VovKa
  • Ukraine
« Reply #7 on: April 13, 2011, 03:21:04 AM »
yep
(vl-file-rename old-fileorfoldername new-fileorfoldername)
« Reply #8 on: April 13, 2011, 08:11:24 AM »
yep
lol, Trust you to find the easy way  :evil:
Oh well, at least I got some practice with the FSO  8-)
alanjt
« Reply #9 on: April 13, 2011, 08:12:43 AM »
yep
Nicely done. :kewl:
Dropbox
pBe
« Reply #10 on: April 13, 2011, 08:50:02 AM »
Another.... CMD/DOS
(defun MoveDos ( File Fldr)
      (startapp "CMD /c" (strcat (vl-prin1-to-string "move /y ") (vl-princ-to-string File) " "
        (vl-princ-to-string Fldr)))
(MoveDos "D:\\File.txt" "D:\\Folder\\")
alanjt
« Reply #11 on: April 13, 2011, 08:51:40 AM »
Lee, would you mind posting the direct link to the documentation you were reading for FSO?
Dropbox
« Reply #12 on: April 13, 2011, 08:54:42 AM »
Sure,
http://msdn.microsoft.com/en-us/library/kxtftw67%28v=VS.85%29.aspx
alanjt
« Reply #13 on: April 13, 2011, 08:55:51 AM »
Dropbox
Dashmonkey
  • (defun sleep nil nil)
« Reply #14 on: April 13, 2011, 04:53:51 PM »
I didn't break it, I swear! ...ok, I broke it.
