Author Topic: create reference greyed out  (Read 2869 times)
drizzt
« on: April 01, 2011, 12:32:47 PM »
Not sure what I did, when I go to Data shorcuts (my working folder is set correctly) and right click on a shorcut, the create reference is greyed out so I can't select it. I tried this with two different projects and both are the same way.
Any clues?
Re: create reference greyed out
« Reply #1 on: April 01, 2011, 12:35:40 PM »
Any clues?
you MUST save the file you are working in with a NAME before you can create any reference(s).
They should have tought you this.   ;-)
drizzt
« Reply #2 on: April 01, 2011, 12:35:53 PM »
I can tell you that I was following a tutorial on how to use the Data Shortcuts Editor before I noticed the greyed out "create reference". I do not know if that created the problem or not.
drizzt
« Reply #3 on: April 01, 2011, 12:36:47 PM »
doh..,!! :oops:
