Author Topic: mapcar list question  (Read 5931 times)
pkohut
« on: March 02, 2011, 01:25:08 PM »
I can't figure out the secret sauce to the following -
Giving 2 lists
L1 = (1.0 2.0 3.0)
L2 = ((1.0 2.0 3.0) (4.0 5.0 6.0) (7.0 8.0 9.0))
How can L1 be added to each sublist in L2?
New tread (not retired) - public repo at https://github.com/pkohut
Re: mapcar list question
« Reply #1 on: March 02, 2011, 01:28:26 PM »
(mapcar (function (lambda ( x ) (mapcar (function +) x L1))) L2)
pkohut
« Reply #2 on: March 02, 2011, 01:50:49 PM »
Thanks Tim. Now how to flatten the returned result
((2.0 4.0 6.0) (5.0 7.0 9.0) (8.0 10.0 12.0))
to
(2.0 4.0 6.0 5.0 7.0 9.0 8.0 10.0 12.0)
as I need to (apply '+ flattenedList)
ps, these are simplified examples for illustration purposes only. The actual 'functions are more complex.
TIA
alanjt
  • Standby for witty remark...
« Reply #3 on: March 02, 2011, 01:53:55 PM »
(apply 'append lst)
Dropbox
pkohut
« Reply #4 on: March 02, 2011, 01:55:37 PM »
(apply 'append lst)
Wonderful.  :-)
pkohut
« Reply #5 on: March 02, 2011, 05:08:15 PM »
Ok, here's where I'm at. Currently looking at some code that is written for Clojure Lisp, which I know zip about.
I can't figure out how to convert the following line of Clojure code to autolisp.
(apply + (map #(VectorSubtract L1 %) L2))Again, it is simplified for illustration purposes. VectorSubtract in AL would be
(defun VectorSubtract (v u / )
    (mapcar '- v u)
Running the code by hand the final result should be (I think)
(9.0 9.0 9.0)
L1 = (1.0 2.0 3.0)
VectorSubtract (1.0 2.0 3.0) (1.0 2.0 3.0) => (0.0 0.0 0.0)
VectorSubtract (1.0 2.0 3.0) (4.0 5.0 6.0) => (3.0 3.0 3.0)
VectorSubtract (1.0 2.0 3.0) (7.0 8.0 9.0) => (6.0 6.0 6.0)
                               Final Result = (9.0 9.0 9.0)
Not knowing the fine art of mapcar, lambda, and other such lispy things, this is just out of my reach.
Again TIA for any help
« Reply #6 on: March 02, 2011, 05:11:37 PM »
Give this a try:
(apply 'mapcar (cons '+ (mapcar '(lambda ( e ) (mapcar '- e l1)) l2)))
pkohut
« Reply #7 on: March 02, 2011, 05:15:29 PM »
Give this a try:
Amazing.
« Reply #8 on: March 02, 2011, 05:36:17 PM »
or if you really wanted to use the VectorSubtract ...
(apply 'mapcar (cons '+ (mapcar '(lambda ( v ) (VectorSubtract v L1)) L2)))
pkohut
« Reply #9 on: March 02, 2011, 09:00:20 PM »
Thanks Kerry, though it didn't produce the expected result it was a good effort. The others produce the correct results with the  quoted function versions, not with my user functions. After lots of futzing around I managed this version of total-gravitaition-force to work. The Clojure Lisp version is there too.
(defun total-gravitational-force (state / tmp pt1 pt2)
  (setq tmp nil
pt1 (cadr (assoc 'player state))
pt2 (cadr (assoc 'obstacles state)))
   (apply 'mapcar (cons '+ (mapcar '(lambda (x) '+ pt1 x) (foreach x pt2 (setq tmp (append tmp (list (gravity-vector pt1 x))))))))
;;;;;; Clojure lisp version of the above ;;;;;;;
(apply + (map #(gravity-vector (:player @state) %) (:obstacles @state))))
Here's the gravity vector function, though it's not implemented right. Need to check out Wikipedia. (the VectorSubtraction test plugin works)
(defun gravity-vector (v u / force uvAngle |u| |v|)
  (setq force (/ 2000.0 (expt (magnitude (mapcar '- u v))) 2.0)
|u| (unit u)
|v| (unit v)
uvAngle (- (atan (cadr |v|) (car |v|)) (atan (cadr |u|) (car |u|))))
  ;(list (* (sin uvAngle) force) (* (cos uvAngle) force) 0.0)
And here is the state date that is fed to the functions.
((PLAYER (237.796 315.332 0.0))
(TARGET (237.796 311.469 0.0))
(OBSTACLES (
    (135.0 223.0 0.0) (560.0 290.0 0.0) (550.0 120.0 0.0)
    (145.0 70.0 0.0) (350.0 320.0 0.0) (60.0 50.0 0.0)
    (210.0 313.0 0.0) (450.0 210.0 0.0))))
(total-gravitational-force state) ;;; returns a UVW vector
« Reply #10 on: March 02, 2011, 09:38:23 PM »
Thanks Kerry, though it didn't produce the expected result it was a good effort. < ... >
Well that's just weird, 'cause it works for me  :)
pkohut
« Reply #11 on: March 02, 2011, 10:16:09 PM »
Yep, working now  :-)  Must have changed something while reforming the statement.
BTW, why does the first mapcar not have a open paren? Is there some rule for when to use an open paren with the quote? Basically why not this
'(mapcar ...
(apply [color=red]'mapcar[/color] (cons '+ (mapcar '(lambda ( v ) (VS v l1)) l2)))
« Reply #12 on: March 02, 2011, 11:37:39 PM »
The quote symbol acts on the following statement.
By using '(xxxxx you are quoting the entire statement included in the braces ...
which produces a completely different result
« Reply #13 on: March 03, 2011, 02:44:02 PM »
'(mapcar ...
The highlighted mapcar is an argument (hence not to be evaluated) to the apply function, and so it is quoted in the same way that the lambda function or '+' function is quoted.
We are effectively doing this (using my original code as an example):
Setting some values:
_$ (setq l2 '((1.0 2.0 3.0) (4.0 5.0 6.0) (7.0 8.0 9.0)))
_$ (setq l1 '(1.0 2.0 3.0))
(1.0 2.0 3.0)
Breaking it down:
_$ (mapcar '(lambda ( e ) (mapcar '- e l1)) l2)
((0.0 0.0 0.0) (3.0 3.0 3.0) (6.0 6.0 6.0))
_$ (cons '+ (mapcar '(lambda ( e ) (mapcar '- e l1)) l2))
(+ (0.0 0.0 0.0) (3.0 3.0 3.0) (6.0 6.0 6.0))
_$ (apply 'mapcar (cons '+ (mapcar '(lambda ( e ) (mapcar '- e l1)) l2)))
(9.0 9.0 9.0)
But notice that:
(apply 'mapcar '(+ (0.0 0.0 0.0) (3.0 3.0 3.0) (6.0 6.0 6.0)))
is the same as:
(mapcar '+ '(0.0 0.0 0.0) '(3.0 3.0 3.0) '(6.0 6.0 6.0))
Hope this helps with the understanding.
pkohut
« Reply #14 on: March 03, 2011, 02:52:16 PM »
But notice that:
is the same as:
Thanks for the clear explanation, especially that last bit. Yesterday I couldn't grasp what the code was doing.
