Author Topic: Error formating code with VLIDE  (Read 3558 times)
m4rdy
« on: November 20, 2010, 04:07:58 AM »
Does anyone know this error (while formating code via VLIDE) ?
Thank you
m4rdy
Autocad 2007, Windows XP
Re: Error formating code with VLIDE
« Reply #1 on: November 20, 2010, 07:55:39 AM »
Never happened to me.
When in doubt shut ACAD down and restart. 8-)
Do it occur again?
m4rdy
« Reply #2 on: November 22, 2010, 10:22:03 AM »
Do it occur again?
Hi CAB,
Thank you for reply, but..
1. Restart Autocad 07 ==> Error still happened.
next...
2. Restart Windows ===> Errror STILL HAPPENED.
next...
3. Autocad 2009 ===>> Error still happened
next...
4. Restart Autocad 2009  ===> fortunately Error STILL HAPPENED. (same error)
  :x :x :cry: :cry: :realmad: :realmad: :pissed: :pissed:
Note : The program works on A2007 and A2009.
m4rdy
« Reply #3 on: November 22, 2010, 10:36:39 AM »
Wow,
Can you post that code segment that will not format?
VovKa
  • Ukraine
« Reply #4 on: November 22, 2010, 11:24:53 AM »
i had the similar once.
something was wrong with quoted lists as far as i remember.
i think i had to change '(1 2 3) to (quote (1 2 3))
m4rdy
« Reply #5 on: November 22, 2010, 09:07:13 PM »
Hi VOVKA,
You're right. After i changed the code from:
(setq header '("No." "Nama" "Luas (m²)" "Keliling (m')" "Kode" "Panjang (m')"))
To :
(setq header (quote ("No." "Nama" "Luas (m²)" "Keliling (m')" "Kode" "Panjang (m')")))
then format selection, everything works well.
I don't know why.
Is there any explanation about that?
Thank you Vovka.
Wow,
Hi CAB, please try with another cad version. May be this error does have any relationship with IDE version, who knows.
Thank you CAB.
m4rdy
« Reply #6 on: November 23, 2010, 10:40:26 AM »
I'm guessing its because the list contains a quote (within the string) perhaps?
« Reply #7 on: November 23, 2010, 10:51:05 AM »
Works OK in ACAD2000
Did you try this version?
(setq header (list "No." "Nama" "Luas (m²)" "Keliling (m')" "Kode" "Panjang (m')"))
« Reply #8 on: November 23, 2010, 10:57:35 AM »
Lee you are correct, the ' should be char 185 but is a quote mark.
Good eye 8-)
« Reply #9 on: November 23, 2010, 10:59:47 AM »
Good eye 8-)
alanjt
  • Standby for witty remark...
« Reply #10 on: November 23, 2010, 11:07:34 AM »
All options work fine in 2009.
Dropbox
m4rdy
« Reply #11 on: November 23, 2010, 11:47:29 PM »
Hi Lee mac,
(setq header '("No." "Nama" "Luas (m²)" "Keliling (m)" "Kode" "Panjang (m)"))
There is no ' (quote) within string, but still error when formating code (A07).
Alan, did you try with above code?
CAB, Yes it works.
Thank you for all replies.
m4rdy
« Last Edit: November 23, 2010, 11:51:00 PM by m4rdy »
