Author Topic: AutoCAD 11 running on Apple  (Read 2310 times)
GDF
« on: October 22, 2010, 05:28:07 PM »
Has anyone tried AutoCAD 11 on Apple?
Re: AutoCAD 11 running on Apple
« Reply #1 on: October 22, 2010, 05:32:38 PM »
11 or 2011  :|
GDF
« Reply #2 on: October 22, 2010, 05:33:32 PM »
Sorry 2011
« Reply #3 on: October 22, 2010, 05:35:25 PM »
Here is Autodesk's MAC disscussion board if you wanting to see what problems people are having.
http://forums.autodesk.com/t5/AutoCAD-for-Mac/bd-p/520/page/3
GDF
« Reply #4 on: October 22, 2010, 05:39:13 PM »
I just heard that AutoCAD will run on native Mac.
Just wondered how vl-registry-delete, vl-registry-write and vl-registry-read work?
sinc
« Reply #5 on: October 22, 2010, 05:49:18 PM »
They don't.  The Autocad for Mac is pretty crippled.  One of the long list of things it doesn't include is VLisp - you get the basic Lisp commands only.  Although it's a little bit irrelevant in this case, since Mac also doesn't have a registry.
GDF
« Reply #6 on: October 22, 2010, 05:55:57 PM »
Thanks for the info...
