Author Topic: Maybe a dumb question...? Counting Blocks  (Read 2442 times)
craigr
« on: October 06, 2010, 12:00:31 PM »
As an example, for you folks that are designing a bldg., and you want to know how many 'type A' doors are on Level 2, how do you come up with the number?
Do you zoom in on the dwg and slowly scan the dwg while counting or is there something in CAD that lists 'There are 23 instances of block reference 'type A'?
craigr
Re: Maybe a dumb question...? Counting Blocks
« Reply #1 on: October 06, 2010, 12:02:21 PM »
AttExt
will work for you
you will need to make a template file to use with it....
C     Character (A - Z)
D     Digit (0 - 9)
F     Width of field (000 - 999)
P     Decimal places (.0 - .999)
Each line in the template file is a "record," which extracts one particular attribute from the drawing.
« Last Edit: October 06, 2010, 12:08:47 PM by Anti Quark »
deegeecees
« Reply #2 on: October 06, 2010, 12:23:24 PM »
bcount
« Reply #3 on: October 06, 2010, 12:26:50 PM »
one could even employ quick filter of the options palette (not sure if lt has this feature)
craigr
« Reply #5 on: October 06, 2010, 12:28:20 PM »
Apparently, bcount is not available in LT.
Attext looks difficult, but I will explore it further.
JCTER
« Reply #6 on: October 06, 2010, 12:32:42 PM »
Do you have the command "quick select" by typing "QSELECT" at the command line?
craigr
« Reply #7 on: October 06, 2010, 12:35:54 PM »
Good idea!!
QSelect works great.
Another one of those that I am embarrassed that I didn't think of. - (Again, I was thinking too hard.)
I guess it was a dumb quesiton. :)
« Reply #8 on: October 06, 2010, 12:44:49 PM »
deegeecees
« Reply #9 on: October 06, 2010, 01:33:19 PM »
Forgot about that.
