Just modify this topic to add a gif picture.
From Mr Stig Smadsen's homepage, I find the useful program to combine trim and extend line in one.
http://intervision.hjem.wanadoo.dk/lisps/touch.lspI am not sure whether Mr Stig Smadsen has post here.
;;; Touch.LSP *
;;; Small routine to align endpoints of lines to an edge. *
;;; The edge have to be a line. *
;;; The routine works by calculating the point of inter- *
;;; section and change the nearest endpoint to that point *
;;; 2001 Stig Madsen, no rights reserved *
(defun C:Tt(/ cmd ent entl spt ept sset a lent lentl lspt lept lint)
(setq cmd (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(command "UNDO" "Begin")
(while (not ent)
(setq ent (car (entsel "Select edge line: ")))
(if ent
(setq entl (entget ent))
(if (/= (cdr (assoc 0 entl)) "LINE")
(setq ent nil)
(setq spt (cdr (assoc 10 entl))
ept (cdr (assoc 11 entl))
(if ent
(redraw ent 3)
(prompt "\nSelect lines to touch edge: ")
(setq sset (ssget '((0 . "LINE")))
a 0
(if sset
(repeat (sslength sset)
(setq lentl (entget (setq lent (ssname sset a)))
lspt (cdr (assoc 10 lentl))
lept (cdr (assoc 11 lentl))
lint (inters spt ept lspt lept nil)
(if lint
(if (< (distance lint lspt) (distance lint lept))
(entmod (subst (cons 10 lint) (assoc 10 lentl) lentl))
(entmod (subst (cons 11 lint) (assoc 11 lentl) lentl))
(setq a (1+ a))
(princ "\nNo objects found")
(redraw ent 4)
(princ "\nNo edge selected")
(setvar "CMDECHO" cmd)
(command "UNDO" "End")
I do a little modification to enlarge the edge type extension, but the extend and trim object still must be lines
I can't write the code to let the extend and trim object also more than lines
;;; Touch.LSP *
;;; modified by qjchen, the edge line can be line or polyline *
(defun C:Ttt (/ cmd ent entl spt ept sset a lent lentl lspt lept lint)
(while (not ent)
(if ent
(if ent
(redraw ent 3)
a 0
(if sset
(setq entttt (ssname sset a))
(setq lint (nth 0 (x_intlst ent entttt acExtendOtherEntity)))
(if lint
(entmod (subst
(cons 10 lint)
(assoc 10 lentl)
lentl
(entmod (subst
(cons 11 lint)
(assoc 11 lentl)
lentl
(setq a (1+ a))
(redraw ent 4)
;;; by kuangdao at xdcad
(defun x_intlst (obj1 obj2 param / intlst1 intlst2 ptlst)
(if (= 'ENAME (type obj1))
(setq obj1 (vlax-ename->vla-object obj1))
(if (= 'ENAME (type obj2))
(setq obj2 (vlax-ename->vla-object obj2))
(setq intlst1 (vlax-variant-value (vla-intersectwith obj1 obj2 param)))
(if (< 0 (vlax-safearray-get-u-bound intlst1 1))
(setq intlst2 (vlax-safearray->list intlst1))
(while (> (length intlst2) 0)
(setq ptlst (cons (list (car intlst2) (cadr intlst2) (caddr intlst2))
ptlst
intlst2 (cdddr intlst2)
ptlst
