Author Topic: Checking a list ...  (Read 2030 times)
Hangman
Checking a list ...
« on: September 28, 2010, 05:54:46 PM »
Afternoon everyone,
I'm having a brain cramp and can't seem to get a simple return, so I'm coming to you guys.
I have the following:
(setq var-a '(1.1 2.2 3.3))
Command: !a
(0.0 1.1 2.2)
Now if I want to check var-a, I THOUGHT I would type the following:
(if (= var-a '(1.1 2.2 3.3))(ALERT "Yahoo"))What I get is
nil
How do I verify the value of var-a ?
Thanks.
Hangman  8)
Drafting Board, Mechanical Arm, KOH-I-NOOR 0.7mm
Re: Checking a list ...
« Reply #1 on: September 28, 2010, 05:56:57 PM »
Maybe try ' equal ' or ' eq ' or maybe even throw in a fuzz factor with one of them.
« Reply #2 on: September 28, 2010, 05:57:41 PM »
Be careful with the various equality tests...
Command: (= '(1 2 3) '(1 2 3))
nil
Command: (eq '(1 2 3) '(1 2 3))
nil
Command: (equal '(1 2 3) '(1 2 3))
T
Similarly for enames:
Command: (setq e (car (entsel)))
Select object: <Entity name: 7ef03940>
Command: (setq f (car (entsel)))
Command: (= e f)
nil
Command: (eq e f)
T
Command: (equal e f)
T
Hangman
« Reply #3 on: September 28, 2010, 06:03:59 PM »
Ohh, ...
EQ & EQUAL
And Equal has the Fuzz factor, thanks Tim.
Thank you guys.  Sorry for the stupidity I'm portraying today.
Hangman  8)
