Author Topic: Create empty safearray from scratch  (Read 2144 times)
roy_043
  • BricsCAD 18
« on: August 28, 2010, 07:22:51 AM »
I have a simple function ListToArray that turns a one-dimensional list into a safearray. It checks for empty list because I haven't been able to create an empty safearray from scratch. Is this in anyway possible?
(defun ListToArray (typ lst)
  (if lst ; check for empty list
    (vlax-safearray-fill
      (vlax-make-safearray
        typ
        (cons 0 (1- (length lst)))
      lst
Re: Create empty safearray from scratch
« Reply #1 on: August 28, 2010, 07:27:14 AM »
An empty variant:
(vlax-make-variant)
roy_043
  • BricsCAD 18
« Reply #2 on: August 28, 2010, 07:35:43 AM »
Thanks for the quick answer. But an empty variant and an empty safearray are different "animals".
(type (ListToArray vlax-vbinteger '(1 2 3 4 5))) => SAFEARRAY
(type (vlax-make-variant)) => VARIANT
fixo
« Reply #3 on: August 28, 2010, 10:59:42 AM »
What about this way
(setq lst nil)
(repeat 99 (setq lst (cons (vlax-make-variant) lst)))
(setq sfar (vlax-safearray-fill
     (vlax-make-safearray vlax-vbvariant
       '(0 . 98))
     lst)
« Reply #4 on: August 28, 2010, 11:04:13 AM »
An empty safearray has a negative upper bound, but positive lower bound. However, you will throw an exception if you try to create this.
Atwist
« Reply #5 on: August 28, 2010, 12:00:42 PM »
Hé Roy_043
Welcome on theswamp
Atwist
roy_043
  • BricsCAD 18
« Reply #6 on: August 28, 2010, 03:30:11 PM »
Thank you Atwist. We meet again!
