Author Topic: corridor to surface  (Read 1676 times)
drizzt
corridor to surface
« on: August 09, 2010, 10:17:50 AM »
I have created a corridor with a daylight slope to an existing surface, and I think I have it the way I want it. My problem is, how do I get it to a surface?
Re: corridor to surface
« Reply #1 on: August 09, 2010, 10:22:33 AM »
go to the Targets and assign that surface you want the link to daylight to...
in your case you can probably use
Click Set All Targets. (although it is a Best Practice to set them by region as your corridors become more complex)
In the Target Mapping dialog box, in the Object Name column, click <Click Here To Set All>.
if that is the question....
OR
Go to the Corriddor Dialog Box, Find the SURFACES Tab, Create a Surface, and insert the Top Links with the Plus Sign, assign the FG style to it....and have a nice day
« Last Edit: August 09, 2010, 08:57:38 PM by eNot That Kind Of Class »
« Reply #2 on: August 09, 2010, 10:28:03 AM »
additionally....to tidy it all up, you will want to add/apply a boundary to the Corridor Surface...on the BOUNDARIES Tab
drizzt
« Reply #3 on: August 09, 2010, 11:16:07 AM »
Thanks!!!!! :-)
