Author Topic: Increment a Number in a String  (Read 9124 times)
SteveK
« on: July 29, 2010, 04:46:53 AM »
I have a string. I need a function that finds the last number in the string and increments it by an integer (parameter) then returns the string again.
I'm sure you can do this with regular expressions but I don't know how.
Example 1: (negative increment)
input string = a3
value to increment = -1
string returned = a2
Example 2: (multiple numbers in the string)
input string = ab12cd34e
value to increment = 2
string returned = ab12cd36e
Example 3: (ignoring decimal places)
input string a1.9b
value to increment = 1
string returned = a1.10b
Programming in C#. Any help is appreciated.
pkohut
Re: Increment a Number in a String
« Reply #1 on: July 29, 2010, 05:01:39 AM »
input string a1.9b
Are the numbers limited to a range and subject to rollover, like an odometer? Can't tell from examples 1 and 2. Example 3 suggests not. Let's clarify using a modified example 2.
input string ab12cd98e
string returned = ab12cd00e or ab12cd100e ??
Similar question for negative increments. And with negative increments, is 0 a floor or are negative results acceptable?
Andrey Bushman
« Reply #2 on: July 29, 2010, 06:00:52 AM »
using System;
using System.Linq;
using System.Text;
namespace ConsoleTest
    class Program
        static void Main(string[] args)
            Console.WriteLine(Incr("asdf123", 5));
            Console.WriteLine(Incr("asdf555_red123", -7));
            Console.Read();
        static string Incr(string text, int increment)
            int i = Int32.Parse(new string(text.Reverse().TakeWhile(n => Char.IsNumber(n)).Reverse().ToArray()));
            string name = text.Substring(0, text.Length - i.ToString().Length);
            return name + (i + increment);
SteveK
« Reply #3 on: July 29, 2010, 06:04:41 AM »
pkohut, I should have added, range is not limited in positive direction, and assume 0 is floor.
Andrey, I will try your code and let you know.
SteveK
« Reply #4 on: July 29, 2010, 06:16:00 AM »
Thanks for the code Andrey. It takes me further along than I was, however I get an error when letters are at the end of my string. The last number can be anywhere in the string, even at the start.
fixo
« Reply #5 on: July 29, 2010, 07:11:48 AM »
input string = a3
input string a1.9b
Hi Steve
Send me test message on my home address
coz I've lost your e-mail
I have complete project (not finished yet,
but it may helps)
I've used RegularExpression to rebuild sttring
~'J'~
SteveK
« Reply #6 on: July 29, 2010, 07:29:09 AM »
Hi Oleg,
You have a complete project? But I'm just after one function!  :-)
steve
Andrey Bushman
« Reply #7 on: July 29, 2010, 07:33:25 AM »
using System;
using System.Linq;
using System.Text;
    class Program
            Console.WriteLine(Incr("asdf555_red123dwq", -2));
            Console.WriteLine(Incr("543asdf", -7));
            Console.WriteLine(Incr("asdf555_red123dwq1", -5));
            Console.WriteLine(Incr("rrasdf", 8));
            Console.Read();
            if (text.Where(n => Char.IsNumber(n)).Count() == 0)
                Console.WriteLine("string '{0}' not contain of number", text);
                return string.Empty;
            string revText = new string(text.Reverse().ToArray());
            string a = new string(revText.TakeWhile(n => !Char.IsNumber(n)).ToArray());
            int b = Int32.Parse(new string(revText.Skip(a.Length).TakeWhile(n => Char.IsNumber(n)).Reverse().ToArray())) + increment;
            string c = revText.Substring(a.Length + b.ToString().Length);
            StringBuilder sb = new StringBuilder();
            sb.Append(a);
            sb.Append(new string(b.ToString().Reverse().ToArray()));
            sb.Append(c);
            return new string(sb.ToString().Reverse().ToArray());
« Last Edit: July 29, 2010, 07:39:58 AM by Hwd »
SteveK
« Reply #8 on: July 29, 2010, 07:41:55 AM »
Thank you Hwd, I can deffinately use this.
Cheers! :-)
Andrey Bushman
« Reply #9 on: July 29, 2010, 08:27:51 AM »
Cheers! :-)
I will forgive pardons - I have skipped an error for it variant string:
"asdf555_red123dwq00001":
I has rectified an error:
using System;
using System.Linq;
using System.Text;
    class Program
            Console.WriteLine(Incr("asdf555_red123dwq00001", -5));//It test add
            Console.Read();
                Console.WriteLine("string '{0}' not contants of nomber", text);
            string z = new string(revText.Skip(a.Length).TakeWhile(n => Char.IsNumber(n)).Reverse().ToArray());
            int b = Int32.Parse(z) + increment;
            if (b > 0)
                z = z.Length == b.ToString().Length ? b.ToString() : new string('0', z.Length - b.ToString().Length) + b;
            else
                z = z.Length == b.ToString().Length ? b.ToString() : new string('0', z.Length + 1 - b.ToString().Replace("-","").Length) + Math.Abs(b);
            string c = revText.Substring(a.Length + z.Length);
            sb.Append(a);
            sb.Append(new string(z.Reverse().ToArray()));
            sb.Append(c);
« Last Edit: July 29, 2010, 08:51:12 AM by Hwd »
SteveK
« Reply #10 on: July 29, 2010, 09:13:30 AM »
Thanks for your help so far Hwd.
I did find another error though. Try for example:
Console.WriteLine(Incr("9a", 1));
Console.WriteLine(Incr("a99b", 1));
Edit: Also, a problem with having Replace("-","") in the code is that sometimes there are hyphen's in the string and it'd remove them.
« Last Edit: July 29, 2010, 09:28:59 AM by steve.k »
Andrey Bushman
« Reply #11 on: July 29, 2010, 09:58:48 AM »
Test it please:
using System;
using System.Linq;
using System.Text;
    class Program
            Console.WriteLine(Incr("999", -11));
            Console.Read();
            string d = z;
            int zc = z.Length - Int32.Parse(z).ToString().Length;// count of 0.
            if (b > 0)
                z = z.Length == b.ToString().Length ? b.ToString() : new string('0', zc) + b;
            else
                z = z.Length == b.ToString().Length ? b.ToString() : new string('0', zc + 1) + Math.Abs(b);
            string c = revText.Substring(a.Length + d.Length);
            sb.Append(a);
            sb.Append(c);
SteveK
« Reply #12 on: July 29, 2010, 10:23:53 AM »
That's better, no errors, thanks:
I was also messing around with it as I've learnt from your code and I came up with:
        return null;
    string y = new string(z.TakeWhile(n => n.Equals('0')).ToArray());
    if (b < 0) b = 0;
    z = b.ToString();
    sb.Append(a);
    sb.Append(y);
    sb.Append(c);
Very similar to yours. Again, thanks for your help Hwd.  :-)
Andrey Bushman
« Reply #13 on: July 29, 2010, 10:31:43 AM »
fixo
« Reply #14 on: July 29, 2010, 11:34:31 AM »
        return null;
    if (b < 0) b = 0;
    z = b.ToString();
    sb.Append(a);
    sb.Append(y);
    sb.Append(c);
Hope you don't mind but how about:
Console.WriteLine(Incr("asdf0004", -5));
~'J'~
