Author Topic: PLINE JOIN  (Read 6988 times)
TJAM51
PLINE JOIN
« on: December 03, 2004, 07:35:01 AM »
I am seeking a routine that will join a pline and offer a crossing or pick without having to go throuh all the PEDIT process....thanks
PLINE JOIN
« Reply #1 on: December 03, 2004, 07:53:27 AM »
If you have express tools use pljoin
PLINE JOIN
« Reply #2 on: December 03, 2004, 08:05:51 AM »
I have this but never tried it.
;;  from Marc'Antonio Alessi (nospam_maalessi_at_tin_dot_it)
; #PlineJoinPrec = global
(defun C:ALE_PlJoin (/ SelSet FltLst OldLPr)
 ;(setvar "CMDECHO" 0) ; I have always = 0
  (princ "\nSelect lines, arcs or polylines to join:  ")
  (setq OldLPr (getvar "LUPREC"))  (setvar "LUPREC" 8)
  (setq
    FltLst
    '((0 . "LWPOLYLINE,POLYLINE,LINE,ARC"))
    #PlineJoinPrec
     (ureal 5 "" "Precision distance" (cond ( #PlineJoinPrec ) ( 0.00001 )))
  (setvar "LUPREC" OldLPr)
    ( (not (setq SelSet (cond ((ssget "_I" FltLst)) ((ssget FltLst)))))
      (prompt "\nNo arc or polyline selected.  ")
    ( (ssget "_P" '((0 . "LINE,ARC")))
      (command "_.PEDIT" "_M" SelSet "" "_Y" "_J" "_J" "_E" #PlineJoinPrec"")
      (princ (strcat
        "\n" (itoa (sslength SelSet))
        " lines, arcs or polylines are joined.  "
    ( T
      (command "_.PEDIT" "_M" SelSet "" "_J" "_J" "_E" #PlineJoinPrec "")
      (princ "\n_ ")
      (princ (strcat "\n " (itoa (sslength SelSet)) " polylines are joined."))
;* UREAL  Funzione di interfaccia utente per numeri reali.
;* BIT (0 per nessuno) e KWD key word ("" per nessuna) sono gli stessi di
;* INITGET.
;* MSG e' la stringa di prompt, alla quale e' aggiunto numero reale di default
;* come <DEF> (nil per nessuno), e un : sara' aggiunto.
(defun ureal (bit kwd msg def / inp)
  (if def
    (setq
      msg (strcat "\n" msg " <" (ALE_RTOS_DZ8 def) ">: ")
      bit (* 2 (fix (/ bit 2)))
    (setq msg (strcat "\n" msg ": "))
  (initget bit kwd)
  (setq inp (getreal msg))
  (if inp inp def)
);defun UREAL
(defun ALE_RtoS_DZ8 (ReaVal / CurDZn OutVal)
  (if (= 8 (setq CurDZn (getvar "DIMZIN")))
    (setq CurDZn nil)
    (setvar "DIMZIN" 8)
  (setq OutVal (rtos ReaVal 2))
  (and CurDZn (setvar "DIMZIN" CurDZn))
  OutVal
SMOKIIBEAR
Re: PLINE JOIN
« Reply #3 on: November 15, 2005, 06:20:04 PM »
HOW CAN THIS ROUTINE BE REWRITTEN SO THAT IT IS NOT NECESSARY TO ENTER FUZZ DISTANCE AT THE COMMAND LINE EACH TIME, BUT THE OPTION COULD BE AVAILABLE?
Re: PLINE JOIN
« Reply #4 on: November 15, 2005, 06:33:57 PM »
If you have a few dollars and don't want to write you own .... GBPoly [ http://www.geometricad.com/ ] You'll find it hard to beat. :-)
DanB
Re: PLINE JOIN
« Reply #5 on: November 16, 2005, 12:22:57 PM »
Here's the one I use...
;; 06/22/05
;; Polyline Joins Selected Objects
  (defun c:j (/ ss)
   (prompt "\nSelect Objects to Join... ")
   (setq ss (ssget))
   (command "pedit" "m" ss "" "j" "" "")
deegeecees
Re: PLINE JOIN
« Reply #6 on: November 16, 2005, 12:46:46 PM »
Very good app.
LE
Re: PLINE JOIN
« Reply #7 on: November 16, 2005, 12:54:13 PM »
Yes....
Here is a link to see GBPOLY in action:
http://www.geometricad.com/app.php?id=1&lang=en
There are a lot of open source, samples on how to join plines, lines and arcs, if you are looking for a smart and easy way to generate closed areas, then give GBPOLY a try.
SMOKIIBEAR
Re: PLINE JOIN
« Reply #8 on: November 16, 2005, 02:44:16 PM »
Ahhh...that makes me happy :lmao:
Thanks.  One of these days, I need to starting writing lisp.
whdjr
Re: PLINE JOIN
« Reply #9 on: November 16, 2005, 03:04:28 PM »
How about sooner that later.
Lisp Forum
Lisp Course Documents
Swift
Re: PLINE JOIN
« Reply #10 on: November 16, 2005, 03:09:11 PM »
Lisp Forum
An Error Has Occurred!
The topic or board you are looking for appears to be either missing or off limits to you
deegeecees
Re: PLINE JOIN
« Reply #11 on: November 16, 2005, 03:16:46 PM »
Lisp Forum
Ditto.
whdjr
Re: PLINE JOIN
« Reply #12 on: November 16, 2005, 03:19:13 PM »
I think that was invitation only forum.  You had to sign up for the class.
Maybe Mark can unlock that for everyone?
edit
Sorry 'bout that guys I forgot.
Re: PLINE JOIN
« Reply #13 on: November 16, 2005, 03:19:24 PM »
I get the same thing .... perhaps when Mark was playing around with the board he got it mal-adjusted ...
jonesy
  • SuperMod
Re: PLINE JOIN
« Reply #14 on: November 17, 2005, 02:47:22 AM »
That was a course that was run by Stig. We had to sign up for the course. I believe its only for the students on Stigs course.
T :-)
