Author Topic: GetRam | GetFreeRam  (Read 4300 times)
GetRam | GetFreeRam
« on: April 22, 2010, 05:12:31 PM »
A colleague needed these today -- in case anyone else has need down the road --
(defun _GetRam ( / wmiLocater wmiService queryResult result )
[color=green]    ;;========================================================================
    ;;  2010/04/22 | Quick & Dirty | Michael Puckett
    ;;========================================================================[/color]
    (vl-catch-all-apply
       '(lambda ( )
            (vlax-for item
                (setq queryResult
                    (vlax-invoke
                        (setq
                            wmiLocater (vlax-create-object "WbemScripting.SWbemLocator")
                            wmiService (vlax-invoke wmiLocater 'ConnectServer "." "root\\cimv2")
                       'ExecQuery
                        (strcat
                            "Select * "
                            "from   Win32_ComputerSystem "
                (setq result (vlax-get item 'TotalPhysicalMemory))
    (if queryResult (vlax-release-object queryResult))
    (if wmiService (vlax-release-object wmiService))
    (if wmiLocater (vlax-release-object wmiLocater))
    (if result (/ (distof result) 1024 1024)) [color=green];; return MB[/color]
(defun _GetFreeRam ( / wmiLocater wmiService queryResult result )
    (vl-catch-all-apply
       '(lambda ( )
            (vlax-for item
                (setq queryResult
                    (vlax-invoke
                        (setq
                       'ExecQuery
                        (strcat
                            "Select * "
                            "from   Win32_OperatingSystem "
                (setq result (vlax-get item 'FreePhysicalMemory))
    (if result (/ (distof result) 1024)) [color=green];; return MB[/color]
cheers
Re: GetRam | GetFreeRam
« Reply #1 on: April 22, 2010, 06:04:33 PM »
Thanks Michael - they work well.
If you have the time, I have a few questions about the code:
  • Why do you use "." for the Server and "root\\cimv2" for the namespace? Are these the defaults?
  • I don't quite understand the structure of SWbemObjectSet that is returned by the ExecQuery, but could you use "Select TotalPhysicalMemory" as opposed to "Select *" ?
Sorry to be a bother.
Lee
« Reply #2 on: April 22, 2010, 06:09:12 PM »
I didn't put much thought  into it to be honest -- I just converted this vbscript code to lisp.
« Reply #3 on: April 22, 2010, 06:12:45 PM »
I did lift this part:
                        (setq
From some previous work I had done and if memory serves Daniel had helped me with it.
« Reply #4 on: April 22, 2010, 06:17:40 PM »
Gotcha - thanks mate  :-)
alanjt
  • Standby for witty remark...
« Reply #5 on: April 22, 2010, 07:43:53 PM »
Cool stuff Michael. Always teaching us something new. :)
Dropbox
VovKa
  • Ukraine
« Reply #6 on: April 23, 2010, 03:03:23 AM »
i wonder why MS guys decided to count "TotalPhysicalMemory" in bytes and "FreePhysicalMemory" in kilobytes?
« Reply #7 on: April 23, 2010, 09:29:25 AM »
I wondered who would be first to catch that. :) When I first wrote them I was like "What  the hell? -- Left hand doesn't know what the right hand is doing".
Andrea
« Reply #8 on: April 23, 2010, 11:19:02 AM »
is something like...
(command "_shell" "mem > c:\\mem.txt")
(startapp "notepad" "c:\\mem.txt")
working ?
Keep smile...
HasanCAD
« Reply #9 on: April 25, 2010, 12:03:34 PM »
I tried to show the resule in an alert box bot not working
(DEFUN C:GetRamF ()
  (setq GetRam_T (_GetRam))
  (setq GetRam_F (_GetFreeRam))
  (alert GetRam_T"\n" GetRam_F)
alanjt
« Reply #10 on: April 25, 2010, 12:13:22 PM »
(DEFUN C:GetRamF ()
Look at strcat to join strings.
eg.
(strcat "H" "E" "L" "P") => "HELP"
Dropbox
HasanCAD
« Reply #11 on: April 25, 2010, 12:17:44 PM »
alanjt
Thanx for your reply
As expected your replies are very fast more than I imagine
alanjt
« Reply #12 on: April 25, 2010, 12:23:22 PM »
Oops, didn't realize the return was a real. You'll have to convert to string first.
Look at RToS or vl-princ-to-string.
Dropbox
HasanCAD
« Reply #13 on: April 25, 2010, 12:32:48 PM »
the 2 previous routines and gives alert message
; o_|_||
;   Subroutine
    (vl-catch-all-apply
       '(lambda ( )
            (vlax-for item
                (setq queryResult
                    (vlax-invoke
                        (setq
                       'ExecQuery
                        (strcat
                            "Select * "
    (if result (/ (distof result) 1024 1024)) ;; return MB
  (vl-catch-all-apply
       '(lambda ( )
            (vlax-for item
                (setq queryResult
                    (vlax-invoke
                        (setq
                       'ExecQuery
                        (strcat
                            "Select * "
    (if result (/ (distof result) 1024)) ;; return MB
; o_|_||
;                          Subroutine
; o_|_||
;  mainroutine
(DEFUN C:GetRamF ()
  (alert (strcat "total Ram = " (rtos GetRam_T) "\nFree ram = " (rtos GetRam_F)))
; o_|_||
;                         mainroutine
Thanx for alanjt
HasanCAD
« Reply #14 on: April 25, 2010, 12:47:07 PM »
I got it after try and error
I tried to use itoa then rtos
This pulling me to ask
Is there a way to know is the result string, intiger or real?
