Author Topic: Searching DataTable  (Read 2484 times)
David Hall
  • Automatic Duh Generator
Searching DataTable
« on: March 11, 2010, 03:50:52 PM »
I am stumped on how to get my search to run.  I copied this code from MSDN
DataTable table = DataSet1.Tables["Orders"];
            // Presuming the DataTable has a column named Date.
            string expression;
            expression = "Date > #1/1/00#";
            DataRow[] foundRows;
            // Use the Select method to find all rows matching the filter.
            foundRows = table.Select(expression);
            // Print column 0 of each returned row.
            for (int i = 0; i < foundRows.Length; i++)
                Console.WriteLine(foundRows[i][0]);
but when I edit it, I get an error about comparing apples and oranges
here is my code
            DataTable table = dataSet1.Tables["DrawingData"];
            DataRow[] foundRow;
            string expression;
            expression = txtDrawingNumber.Text; //"DrawingNumber = " +
            foundRow = table.Select(expression);
            int i = foundRow.Length;
            if (i == 0)
                dataSet1.Tables["DrawingData"].Rows.Add(rw);
                txtDrawingNumber.Text = String.Empty;
                dataSet1.Tables["DrawingData"].WriteXml(@"c:\test.xml");
                txtDrawingNumber.Focus();
At this point I probablly have extra crap in there as I was trying to figure out what was going on.
Glenn R
Re: Searching DataTable
« Reply #1 on: March 11, 2010, 04:17:39 PM »
Hmmm...DataSet, DataTable and a DataView...i did this a few years ago with 1000's of layer names...I'll see if I can dig it up...give me a few...
BTW, you don't mention the error or spefically what you're trying to do Duh...
Glenn R
« Reply #2 on: March 11, 2010, 04:27:37 PM »
Duh,
Just had a quick look at my code (it's in a repository and it's late: read - I'm sure I've used a DataView as I found it it was far quicker), but try wrapping you're DrawingNumber in single quotes, ala:
"DrawingNumber = '" + SomVariable + "'"
David Hall
« Reply #3 on: March 12, 2010, 10:04:00 AM »
Thanks Glenn, I will go test that now.
David Hall
« Reply #4 on: March 12, 2010, 10:51:34 AM »
Glenn, you were spot on, that was it.  Now my question is why would that make a difference?  When concatenating strings, did not the .Text return a string?
fixo
« Reply #5 on: March 12, 2010, 12:35:53 PM »
Commandor, how about:
expression = "DrawingNumber = '" + DateTime.Parse(txtDrawingNumber.Text.ToShortDateString() + "'";
(not tested)
~'J'~
David Hall
« Reply #6 on: March 12, 2010, 01:27:42 PM »
Thanks Fixo!  The date time thing was from the example on MSDN, I was just trying to use a string from a textbox
Glenn R
« Reply #7 on: March 12, 2010, 02:43:39 PM »
When you're doing filters like these, you find that you need to single quote the right hand value of the equals expression...I seem to remember this was the case for searching XML with XPATH expressions as well.
Glenn R
« Reply #8 on: March 12, 2010, 02:44:26 PM »
To answer your question specifically Duh, yes, .Text did return a string.
David Hall
« Reply #9 on: March 12, 2010, 05:03:11 PM »
Thanks Glenn!  I thought I was doing it right, but I just could not make it work.  the single quote worked the first time through.  My next challenge is to grab the row where it found it and return a column to the right.  More reading tonight
