Author Topic: Dynamic Block Properties  (Read 7819 times)
« on: January 06, 2010, 07:26:00 PM »
This is new ground for me, so bear with me a bit...  :wink:
A recent thread involved modifying dynamic block properties, and so I thought I'd finally give it a shot at learning how to do it.
I've done a search on here, but, although I have found methods, and threads relating to it, I still have an outstanding query.
Say I am trying to enter a Dynamic Block Property after insertion, knowing its Property Name.
I am currently using methods along these lines:
(foreach Prop (vlax-invoke obj 'GetDynamicBlockProperties)
  (if (eq <PropName> (vla-get-PropertyName Prop))
    (vla-put-value Prop
      (vlax-make-variant <New Value>
        (vlax-variant-type
          (vla-get-value Prop))))))
And have also tried:
    (vlax-put-property Prop 'Value <New Value>)))
But, when entering some values, (namely zero), I get: ** Automation Error: Invalid Input **
Could this be due to the Dynamic Block that I am using? Or the method I am using to enter the value?
Once again, I stress - I have never used Dynamic Blocks before, and don't even know how to make them, and so I can only test on blocks that I find in threads...  :cry:
Any advice is appreciated.
Lee
Re: Dynamic Block Properties
« Reply #1 on: January 06, 2010, 07:33:12 PM »
This worked just fine for me
(foreach i (vlax-invoke ob2 'getdynamicblockproperties)
    (if (= "Visibility" (vla-get-PropertyName i))
        (vla-put-Value i "Elevation")
Maybe you should test to make sure it is an allowed value to enter.
; IAcadDynamicBlockReferenceProperty: AutoCAD Dynamic Block Property Interface
; Property values:
;   AllowedValues (RO) = ("Detail" "Elevation" "Section" "Section-Single" "Section-Double")
;   Description (RO) = ""
;   PropertyName (RO) = "Visibility"
;   ReadOnly (RO) = 0
;   Show (RO) = -1
;   UnitsType (RO) = 0
;   Value = "Detail"
« Reply #2 on: January 06, 2010, 07:55:35 PM »
Ahh... I didn't realise there were values you were "allowed" to enter!
Thanks Tim, that solves it!
At least I learnt a lot with my digging  8-)
gile
  • Marseille, France
« Reply #3 on: January 07, 2010, 03:01:52 AM »
Hi Lee,
Maybe you can get some inspiration from this one.
« Reply #4 on: January 07, 2010, 05:41:29 AM »
Hi Lee,
Many thanks Gile, I'll check it out  :-)
Oak3s
« Reply #5 on: October 21, 2010, 08:35:00 PM »
How do I find this information for my DB?
; Property values:
;   ReadOnly (RO) = 0
;   Show (RO) = -1
;   Value = "Detail"
Also, I am not doing to well trying to follow that code? Could someone help me out. Below is the code T.Willey posted. I attempted to change what I thought was necessary but its a no go :)
(defun c:dyn (/)
(foreach i ;variable that each element in the list will be assigned to
(vlax-invoke-method ob2 'getdynamicblockproperties) ;list to be stepped through and evaluated
(if (= "Width" (vla-get-PropertyName i)) ;expression to be evaulated for each element in list
    (vla-put-Value i "6")
Oak3s
« Reply #6 on: October 21, 2010, 08:45:08 PM »
I spend time trying to figure something out myself and then post...5 minutes later I find something. :)
Okay, so first I need to assign the VLA-object...right?
(setq ob2 (vlax-ename->vla-object(car(entsel))))
I dont know if that is the proper way to do it but its what I found.
So after that I can get the property list T.Willey showed by:
(vlax-dump-object ob2 T)Again, I dont know if that is the proper way but it is what I found. :)
I am going to continue digging. Not solved for me yet.
Oak3s
« Reply #7 on: October 21, 2010, 09:21:24 PM »
:( I lied. the vlax-dump wasnt giving me the dynamic properties like the example posted above.
m4rdy
« Reply #8 on: October 22, 2010, 03:29:35 AM »
Q & R
(mapcar (function (lambda (x) (vlax-dump-object x T)))
(vlax-safearray->list
  (vlax-variant-value
    (vla-getdynamicblockproperties
      (vlax-ename->vla-object (car (entsel)))
);_===>> he..he..he
« Last Edit: October 22, 2010, 08:08:20 AM by m4rdy »
Autocad 2007, Windows XP
Gliderider
« Reply #9 on: October 22, 2010, 07:18:41 AM »
misplaced parenthesis ^^^^^^^
(mapcar
    (vlax-variant-value
      (vlax-ename->vla-object (car (entsel))))
« Reply #10 on: October 22, 2010, 08:09:07 AM »
< .. snip .. >
looks like I'm not the only one who posts code untested  :wink:
m4rdy
« Reply #11 on: October 22, 2010, 08:10:01 AM »
Oops ... Edited above.
mardi
« Reply #12 on: October 22, 2010, 06:58:32 PM »
My dump was a dump of each dynamic property of the block, so you would code it up like
(foreach i (vlax-invoke (vlax-ename->vla-object (car (entsel))) 'GetDynamicBlockProperties)
(vlax-dump-object i T)
)(princ)
Then select a dy block.
Oak3s
« Reply #13 on: October 22, 2010, 07:12:24 PM »
That works well. How can it be modified to use entlast rather than entsel?
As I understand it entlast isnt reterning the pickpoint. I dont understand why that is effecting vlax-ename->vla-object...doesnt that just need the name?
Ah, this is making my head hurt. (that might make it into the 'out of context' thread)
« Reply #14 on: October 22, 2010, 07:17:07 PM »
' vlax-ename->vla-object ' just needs an ename, so if you want to use ' entlast ', replace ' (car (entsel)) ' with ' (entlast) '.
