Author Topic: dimensioning - which do you prefer...  (Read 4466 times)
chrisdarmanin
« on: November 17, 2009, 03:01:09 AM »
...from the two shown here?
this is for a working drawing to be sent on site...
i usually do drawings like the first one
Willie
  • Going nowhere slowly
Re: dimensioning - which do you prefer...
« Reply #1 on: November 17, 2009, 04:19:37 AM »
The first one look better.
I don't like the text to be squeezed between the line in the second one.  I think it's easier to read over the squeezed text.
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
chrisdarmanin
« Reply #2 on: November 17, 2009, 04:39:00 AM »
i think so too
my aim is to make the drawing less crowded... any ideas on how to achieve it without change the scale of the drawing? because i could change the drawing from 1:100 to 1:50 but that would change my paper size to isoA2 to isoA0
Rob...
« Reply #3 on: November 17, 2009, 07:48:35 AM »
I usually size ductwork like the first one. Personally, I think it's not crowded at all. I'm usually trying to fit 10 lbs of stuff in a 5 lb box.
CAD Tech
chrisdarmanin
« Reply #4 on: November 17, 2009, 07:55:00 AM »
everyone seems to like the first one even at the office :D
maybe it will look better if i choose a narrower font.....
SDETERS
« Reply #5 on: November 17, 2009, 08:21:14 AM »
I do not like either one.  There is text overlaying borders, dimensions and other text.  Why is this?
If I had to choose I would choose #2
Rob...
« Reply #6 on: November 17, 2009, 08:22:53 AM »
Good points.
CAD Tech
chrisdarmanin
« Reply #7 on: November 17, 2009, 08:24:01 AM »
that part is not crowded but others are...
that is just part of a drawing which i drew a rectangle quicky around what i wanted printed... i didnt bother about the borders... the important part is the dimensioned ducting
chrisdarmanin
« Reply #8 on: November 17, 2009, 08:29:26 AM »
here is the full drawing FYI
« Reply #9 on: November 17, 2009, 08:48:19 AM »
When I look at the first drawing, it feels disorganized with the leaders, but the second option appears doesn't seem to work with the text (sometimes) crammed in a tight area (i.e. the 200x100 & 200x150 ducts).
I have seen it done both ways on various projects ... but probably the best way I have seen it done is with a schedule in the drawing and an identifying mark, similar to how doors and windows are identified on many drawings.
If I have to choose one of the two though, I choose the second drawing, but maybe adjust the text height slightly to maintain readability.
chrisdarmanin
« Reply #10 on: November 17, 2009, 08:54:05 AM »
yes it does look disorganized and i dont like it... i havent found a system that works yet...
i never considered the schedule method, but wouldn't you end up with a huge schedule in the end that way?
maybe also a .shx fonts will look better such as romans
« Reply #11 on: November 17, 2009, 09:03:09 AM »
it really depends on how many different duct sizes you have .. from the looks of the full drawing, a schedule would probably be about as big as the "Air Control Devices Schedule", but I can see how on a very large project it could become unwieldy ... fortunately for me, we usually only do projects less than 10000 sf and the ductwork is limited.
Good luck on getting it worked out!
chrisdarmanin
« Reply #12 on: November 17, 2009, 09:15:56 AM »
what type of notation do you use? and do you still use leaders or put the text in the duct? or another way?
thanks for your comments :)
« Reply #13 on: November 17, 2009, 09:53:44 AM »
We don't do these types of drawings. When we receive them from the HVAC guys, we simply put a title block on the drawing and add it to our drawing set to be issued for contruction.
The way it is generally presented is with the notation text on top of the duct, similar to your second drawing, except it is enclosed in a rectangle with the duct hidden behind it. I think they use an attributed block with a wipeout
Bob Garner
« Reply #14 on: November 17, 2009, 10:16:52 AM »
I like the first drawing in so far as it is going to be used in the field.  The duct sizes are all horizontal so the field personnel don't have to turn it around like a bus steering wheel to read everything.
