Author Topic: -={ Challenge }=- Matrix Determinant  (Read 14681 times)
chlh_jd
Re: -={ Challenge }=- Matrix Determinant
« Reply #15 on: January 26, 2011, 03:57:15 AM »
all Great !  :-o
before this , I have been use Gile's deter function , it's so fast ,Thanks Gile !
Evgeniy's fastest , Thank you !
But now I test the matrix (det-g '((1 2 3) (2 4 5) (3 5 6))) , It take wrong result  0 , not the corret -1.
« Last Edit: January 26, 2011, 04:09:18 AM by chlh_jd »
Brick_top
« Reply #16 on: January 26, 2011, 04:40:53 AM »
The sad part is that I don't even know what this is for  :oops:
edit - even sadder is that I didn't  read the explanation in the first post
edit 2 - now that I read it I don't understand it... Unfortunately I could go on and on
sorry for the off topic
« Last Edit: January 26, 2011, 05:30:30 AM by Brick_top »
SOFITO_SOFT
« Reply #17 on: January 26, 2011, 08:29:03 AM »
If it is necessary concise:
(defun d(l)(if l(*(caar l)(d(mapcar'(lambda(a)(mapcar'(lambda(b c)(- b(* c(/(car a)1.(caar l)))))(cdr a)(cdar l)))(cdr l))))1))
BravoooOOOO !!!  :lol:
chlh_jd
« Reply #18 on: February 05, 2011, 08:18:09 AM »
Hi Sofito_soft
Hi ElpanovEvgeniy
Is it my PC problem ? I test the matrix '((1 2 3) (2 4 5) (3 5 6)) , however , your functions 'det-g or 'd din't give the correct result  :angel:
SOFITO_SOFT
« Reply #19 on: February 06, 2011, 07:44:40 AM »
Hello people of the swamp:
chlh_jd:
proceedings are divisions, so the numbers to drive must be real, not integers. :|
Please try with '((1.0 2. 3.) (2. 4. 5.) (3. 5. 6.))   :-o
Greetings. :-)
SOFITO_SOFT
« Reply #20 on: February 06, 2011, 07:54:10 AM »
chlh_jd:
not all determinants also has a solution!
For example, if 2 lines are dependent, can not be resolved.
((1 2 3) (3 6 9 ).....) has no solution because (1 2 3) x 3 = (3 6 9). They are dependent! ;-)
There are more cases that has no solution.  :oops:
Greetings  :-)
gile
  • Marseille, France
« Reply #21 on: February 06, 2011, 08:40:09 AM »
chlh_jd:
Greetings  :-)
It seems to me that in these cases the routine have to return 0.0.
Anyway, here's another solution using Gauss pivot (the matrix determinant is equal to the product of all the pivots used in a Gauss-Jordan elimination)
This method should be much more faster with large dimension matrices.
(defun gc:determ (mat / col piv row res det)
  (setq res 1.)
  (while (< 2 (length mat))
    (setq col (mapcar '(lambda (x) (abs (car x))) mat))
    (repeat (vl-position (apply 'max col) col)
      (setq mat (append (cdr mat) (list (car mat))))
    (if (equal (setq piv (float (caar mat))) 0.0 1e-13)
      (setq mat nil
    res 0.0
      (setq row (mapcar '(lambda (x) (/ x piv)) (car mat))
    mat (mapcar
  '(lambda (r / e)
     (setq e (car r))
     (cdr (mapcar '(lambda (x n) (- x (* n e))) r row))
  (cdr mat)
    res (* piv res)
  (setq det (- (* (caar mat) (cadadr mat)) (* (caadr mat) (cadar mat))))
  (if (equal 0. det 1e-14)
    0.
    (* res det)
« Last Edit: February 06, 2011, 01:01:21 PM by gile »
SOFITO_SOFT
« Reply #22 on: February 06, 2011, 03:14:40 PM »
Indeed Gille:
not all determinants also has a solution! <<<< with the LSP program....
For example, if 2 lines are dependent, can not be resolved <<<< with the LSP program....
As you say, should return 0
Regards.
gile
  • Marseille, France
« Reply #23 on: February 06, 2011, 03:32:34 PM »
Indeed Gille:
Regards.
Did you try all the upper routines with: '((1. 2. 3.) (3. 6. 9.) (7. 5. 3.)) for example ?
All resolve the problem returning 0.0
chlh_jd
« Reply #24 on: February 09, 2011, 11:02:52 AM »
Hi  SOFITO_SOFT
I've test in real , it take a wrong result yet .
Hi All ,
How to invers this matrix :
'((7.0 0.0 -3.0 2.0 0.0 -4.0 -4.0 2.0) (0.0 13.0 2.0 -1.0 -4.0 0.0 2.0 -12.0)
(-3.0 2.0 7.0 -4.0 -4.0 2.0 0 0) (2.0 -1.0 -4.0 13.0 2.0 -12.0 0 0) (0.0 -4.0
-4.0 2.0 7.0 0.0 -3.0 2.0) (-4.0 0.0 2.0 -12.0 0.0 13.0 2.0 -1.0) (-4.0 2.0 0 0
-3.0 2.0 7.0 -4.0) (2.0 -12.0 0 0 2.0 -1.0 -4.0 13.0))
It's a matrix of a cantilever beam  for Finite element analysis , It can be inversed by 'MatLab' .
However , all above codes returns nil or 0.0 ?
Therefore, is there some way to use scientific notation to represent  intermediate values or  results ?
« Last Edit: February 09, 2011, 11:12:43 AM by chlh_jd »
jbuzbee
« Reply #25 on: February 09, 2011, 02:02:36 PM »
Please stop - you're all scaring me!  :|
 :lol:
James Buzbee
Windows 8
SOFITO_SOFT
« Reply #26 on: February 10, 2011, 03:49:56 PM »
glubssss ....I do not get to much .... I use "Calc3D ".....
greetings
chlh_jd
« Reply #27 on: February 15, 2011, 12:27:41 AM »
Excellent Gile !
Thank you for your Gauss Way determent fun .
chlh_jd
« Reply #28 on: February 15, 2011, 12:31:45 AM »
Is it can change a lit ? Because it will get a null 'mat' in some case , E.G. the matrix in 'Reply #25 on' .
(if mat (setq det (- (* (caar mat) (cadadr mat)) (* (caadr mat) (cadar mat)))) (setq det 0.0))
« Last Edit: February 15, 2011, 12:34:48 AM by chlh_jd »
ribarm
  • Marko Ribar, architect
« Reply #29 on: December 18, 2019, 06:30:34 PM »
I've added my new version here :
http://www.theswamp.org/index.php?topic=45666.msg597622#msg597622
Regards, M.R.
M.R. on Youtube
