Author Topic: Image Menu Size?  (Read 5995 times)
Image Menu Size?
« on: November 09, 2004, 11:41:26 PM »
Is there a way to increase the window box size on an image menu?
***IMAGE
**WALLI1
[Select Wall Type]
[opticadd(wal-side,Wall Edge)]^C^C$S=X $S=WALLS1
[opticadd(wal-cent,Wall Centered)]^C^C$S=X $S=WALLS2
[opticadd(wal-fnd,Foundation)]^C^C$S=X $S=FNDWALL
[opticadd(grade-bm,Grade Beam)]^C^C$S=X $S=FNDWALL
[ Exit]^C^C
PS here is some reference material - autocad book in PDF form
http://www.software.ufl.edu/autodesk/manuals/a2kcust/
Dommy2Hotty
Image Menu Size?
« Reply #1 on: November 10, 2004, 01:52:43 AM »
Yes, you can increase the size...and add 4 more image boxes...but it involves changing the ACAD.DCL.  There was a post on the AutoDesk usergroups...I changed mine at work just to see it...I'll post the code in the morning...
Image Menu Size?
« Reply #2 on: November 10, 2004, 09:09:26 AM »
Thanks Dommy, looking forward to it.
Image Menu Size?
« Reply #3 on: November 10, 2004, 10:12:23 AM »
CAB, in the ACAD.DCL, where D2H was speaking about, you can shange the size of the images themselves by either reducing the number of images in the dialog (comment out some of them) or by specifying the size of the image in the DCL file.
DCL CODE
acad_icon: dialog {
        key = "label";
        initial_focus               = "listbox";
        : row {
            : list_box {
                width               = 20;
                height              = 21;
                fixed_height        = true;
                key                 = "listbox";
                allow_accept        = true;
            : column {
                : row {
                    : icon_image {
//add width key here on each of the icon_image tiles
                        width       = 20;
//I used 20 as an example, you can use what you need to make the size correct
                        key         = "icon1";
                    : icon_image {
                        key         = "icon2";
                    : icon_image {
                        key         = "icon3";
                    : icon_image {
                        key         = "icon4";
                : row {
                    : icon_image {
                        key         = "icon5";
                    : icon_image {
                        key         = "icon6";
                    : icon_image {
                        key         = "icon7";
                    : icon_image {
                        key         = "icon8";
                : row {
                    : icon_image {
                        key         = "icon9";
                    : icon_image {
                        key         = "icon10";
                    : icon_image {
                        key         = "icon11";
                    : icon_image {
                        key         = "icon12";
                : row {
                    : icon_image {
                        key         = "icon13";
                    : icon_image {
                        key         = "icon14";
                    : icon_image {
                        key         = "icon15";
                    : icon_image {
                        key         = "icon16";
                : row {
                    : icon_image {
                        key         = "icon17";
                    : icon_image {
                        key         = "icon18";
                    : icon_image {
                        key         = "icon19";
                    : icon_image {
                        key         = "icon20";
 *              : row {
 *                  : icon_image {
 *                      key         = "icon21";
 *                  : icon_image {
 *                      key         = "icon22";
 *                  : icon_image {
 *                      key         = "icon23";
 *                  : icon_image {
 *                      key         = "icon24";
        : row {
            : row {
                spacer_0;
                : row {
                    fixed_width = true;
                    : button {
                        label = "&Previous";
                        key = "prev";
                        width = 8;
                    :spacer {
                        width = 2;
                    :button {
                        label = "  &Next  ";
                        key = "next";
                        width = 8;
                spacer_0;
            spacer;
            ok_cancel;
Notice the last four images are commented out with a block comment, you can comment out more to make the images resize automatically. AutoCAD will page the extra icons automatically.
Dommy2Hotty
Image Menu Size?
« Reply #4 on: November 10, 2004, 10:34:26 AM »
Here's how mine ended up after messing with it...
acad_icon: dialog {
        key = "label";
        : row {
            : list_box {
                width               = 20;
                height              = 26;
                fixed_width    = false;
                key                 = "listbox";
            : column {
                : row {
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon1";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon2";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon3";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon4";
                : row {
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon5";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon6";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon7";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon8";
                : row {
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon9";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon10";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon11";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon12";
                : row {
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon13";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon14";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon15";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon16";
                : row {
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon17";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon18";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon19";
                    : icon_image {
                width    = 22;
                height    = 7;
                        key         = "icon20";
               : row {
                   : icon_image {
                width    = 22;
                height    = 7;
                       key         = "icon21";
                   : icon_image {
                width    = 22;
                height    = 7;
                       key         = "icon22";
                   : icon_image {
                width    = 22;
                height    = 7;
                       key         = "icon23";
                   : icon_image {
                width    = 22;
                height    = 7;
                       key         = "icon24";
        : row {
            : row {
                spacer_0;
                : row {
                    fixed_width = true;
                    : button {
                        key = "prev";
                        width = 8;
                    :spacer {
                        width = 2;
                    :button {
                        label = "  &Next  ";
                        key = "next";
                        width = 8;
                spacer_0;
            spacer;
            ok_cancel;
Image Menu Size?
« Reply #5 on: November 10, 2004, 10:40:26 AM »
Thanks Keith...
I there a way to make the image routine dynamic?
If I were designing it I would try to make it dynamic in two ways.
1. to get the display resolution and increase the size to fit the display area
  with limits of course. My resolution is 1280x1024 and the text on the slides
  is not readable.
2. vary the number of image frames with the number needed. So if you had only four
    frames make it a 2x2 array.
I am guessing the lisp code that uses the DCL is in ACAD.LSP. Perhaps some minor
modification is possible.
Image Menu Size?
« Reply #6 on: November 10, 2004, 10:49:51 AM »
Is the filter dialogue located in this same acad.dcl file? I've wanted to change the size of the properties list window for quite a while. Anyone know how to do this?
http://www.theswamp.org/screens/ronjonp/filter.png
Thanks,
Ron
Also....how do I get an image to show up in the message rather than a link??
« Last Edit: April 24, 2006, 10:50:50 AM by ronjonp »
Image Menu Size?
« Reply #7 on: November 10, 2004, 10:51:58 AM »
Thanks Dommy..
Comparing your example with Keith's it looks like you only need to set the
Height & Width in the first Image and the rest will follow.
I'm going to give it a try.
Dommy2Hotty
Image Menu Size?
« Reply #8 on: November 10, 2004, 10:53:09 AM »
Quote from: CAB
Thanks Dommy..
No...they're seperate...unless I did something wrong...
Image Menu Size?
« Reply #9 on: November 10, 2004, 10:53:32 AM »
CAB, you have to set the width on each tile, the height is not required if the aspect ratio is not overriden from the icon_button tile.
There was a routine I wrote some time ago, I am not sure if it was here or on the "other" site...that would create a dynamic DCL. The main thing is that you would have to use a lisp rather than the built in AutoCAD image_icon menu.
You could create the base DCL as code, calculate the resolution (using activex) write out the image sizes and counts using the info from the tile count and resolution of screen to a temp file thae load that DCL
Image Menu Size?
« Reply #10 on: November 10, 2004, 11:02:02 AM »
Quote from: ronjonp
http://www.theswamp.org/screens/ronjonp/filter.bmp
Thanks,
Ron
The filter dialog is defined in filter.dcl you can change the width and height of the list, but you will need to make sure the rest of the dialog looks correct otherwise it might get real ugly.
Use the [img] tag to put a picture in line
Image Menu Size?
« Reply #11 on: November 10, 2004, 11:29:47 AM »
Quote from: Keith
Looked for you routine both places. No luck.
Any chance you can find it?
Image Menu Size?
« Reply #12 on: November 10, 2004, 11:38:01 AM »
I'll look
No luck
Can't even find it on my computer ....
It would be as simple as creating a lisp with a loop to write out the required data to a temp dcl file.
Image Menu Size?
« Reply #13 on: November 10, 2004, 11:54:31 AM »
In AutoCAD 2005 the filter dialogue is in C:\Program Files\AutoCAD 2005\acfilterres.dll.
Here is the original dialogue supplied with AutoCAD 2005:
Here is the modified dialogue that doesn't cut off the properties:
If you want the modified dll for AutoCAD 2005....here it is:
http://theswamp.org/lilly_pond/ronjonp/acfilterres.dll?nossi=1
Ron :D
« Last Edit: December 12, 2005, 12:25:02 PM by ronjonp »
Image Menu Size?
« Reply #14 on: November 10, 2004, 12:14:53 PM »
Good job Ron, would you tell us how you did that exactly.
