Author Topic: Cannot netload dll from C# 4.0  (Read 5425 times)
csharpbird
« on: October 22, 2009, 02:41:53 AM »
It seems that we cannot use the latest visual studio 2010 in AutoCAD.
When I netload the dll compiled by Visual studio 2010,I get the following error message:System.BadImageFormatException.
Glenn R
Re: Cannot netload dll from C# 4.0
« Reply #1 on: October 22, 2009, 05:08:37 AM »
Is your 2010's config set to use a specific framework version?
« Reply #2 on: October 22, 2009, 06:53:27 AM »
 yep, looks like it's broke.  :-(
csharpbird
« Reply #3 on: October 22, 2009, 06:55:41 AM »
When I load a DLL using "NetLoad" command, I get the following error message:
Cannot load assembly. Error details: System.BadImageFormatException: Could not
load file or assembly 'file:///E:\Users\Administrator\Documents\Visual Studio
2010\Projects\ClassLibrary1\ClassLibrary1\bin\Debug\ClassLibrary1.dll' or one
of its dependencies. This assembly is built by a runtime newer than the
currently loaded runtime and cannot be loaded.
csharpbird
« Reply #4 on: October 22, 2009, 08:58:27 AM »
But AU 2009 will have the class "Using .NET 4.0 with AutoCADŽ".(http://au.autodesk.com/?nd=e_class&session_id=5164)
Class Description
Learn how you can use new features of version 4.0 of the .NET framework to create customizations for AutoCAD even easier than before. See how the Dynamic Language Runtime (DLR) and Languge Integrated Query (LINQ) enables experimentation and productivity without sacrificing (too much) performance.
« Reply #5 on: October 22, 2009, 10:38:54 AM »
Same here, with VS2010 beta 1, I was able to goof with the acad.exe.config file to get the modules to load, not so with beta 2.
mohnston
  • CAD Programmer
« Reply #6 on: October 23, 2009, 02:15:31 PM »
Class Description
I'm noticed that session. Since I get to go this year I signed up for it. Stay tuned.
CAD Programming Solutions
sinc
« Reply #7 on: October 24, 2009, 11:15:09 AM »
Unless that class gets pulled because the instructor discovers nothing works with VS 2010 Beta 2...   :lol:
