Author Topic: Problem with drop-down...2K10  (Read 1894 times)
t-bear
« on: September 04, 2009, 03:25:14 PM »
Have a question for the gurus out there.  We upgraded to 2K10 and I'm trying to figure out silly things like CUIs and custom toolbars....  Ran into something I can't figure out.  There isn't a UCS drop-down in 10...or I can't find it.  Like this:
How are these created?  As I'm a bit brain-dead with this stuff, how complicated would it be?  I would *like* to have this rather than a fly-out, but if this takes "programming", I'm gonna have to go with the latter.  Thanks gang....have a great Holiday weekend.  See you all on Tuesday....if I survive the BBQ!!!  :evil:
Re: Problem with drop-down...2K10
« Reply #1 on: September 04, 2009, 04:20:04 PM »
It looks like you will be creating (or recreating) this toolbar.
Or be forced to adopt the Ribbon Mentality.
t-bear
« Reply #2 on: September 04, 2009, 05:04:40 PM »
Thanks Michael...Kinder whut I figgerd.... :roll:  I'll pass on the ribbons for now, thank you.  Just want this new workspace to look as much like the old as possible for now...have too much work to be re-learning AutoCAD.  When we get the time, I'll look into the *new* bells-n-whistles.
« Reply #3 on: September 04, 2009, 05:46:32 PM »
And it must be all so terribly intuitive.  (NOT)
otherwise how does one explain this wonderful document : http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=13252970&linkID=9240697
How do I customize the Ribbon?
Published date: 2009-May-11
Applies to:
AutoCADŽ Civil 2010
AutoCADŽ Civil 3DŽ 2010
Issue
You would like to customize the new Ribbon Interface to suit your needs.
Solution
For detailed instructions, search on the topic "Customize the Ribbon" in the Help menu.
Uh, people, if the Help menu was doing a decent job of explaining the process or concepts would we be looking here for MORE help than help has already provided?
You know what I'm saying???
Crank
« Reply #4 on: September 05, 2009, 04:40:45 AM »
[...]  There isn't a UCS drop-down in 10...or I can't find it.  [...]
What you are looking for is UCS Control.
Change in the CUI 'All Commands Only' to 'All Commands and Controls'.
Drag 'UCS Control' to your toolbar.
Another option is to use your old .CUI and compile that to CUIx, or use transfer for the things that you need.
t-bear
« Reply #5 on: September 08, 2009, 04:53:41 PM »
Thanks Crank...think I've fingered it out....LOL  Took a while, but in spite of all the "help" in the help files, I found it.... thet'll teach the barstids!
« Reply #6 on: September 08, 2009, 05:22:33 PM »
way to go T-Bear!
go Team Swamp!
Thanks Crank!
<UCS Control> Exactly what one would think of for their Views...NOT!
t-bear
« Reply #7 on: September 09, 2009, 11:18:13 AM »
way to go T-Bear!
go Team Swamp!
Thanks Crank!
Well I shudda thunk a thet raht off!  LOL
I knew what I wanted...just didn't know what the divil it was called!  Them's "controls".....who'd a guessed?
That's the beauty of a family like this...someone will already have been there...done that.  And they're more than willing to help out. Thanks gang, and a special atta-boy for Crank!
It's slowly coming together now...............
