Author Topic: Drawing List  (Read 1036 times)
Matt__W
  • I like my water diluted.
Drawing List
« on: June 26, 2009, 03:02:46 PM »
Can someone point me in the right direction?  I'm looking for a "typical" or "standard" drawing organization list.  I.E. the order of the sheets in the set - mainly architectural/interior/furniture & equipment sheets.  And... since I don't do architecture, I thought I'd ask around.
Thanks.
Autodesk Expert Elite
Daniel J. Ellis
Re: Drawing List
« Reply #1 on: June 28, 2009, 05:58:06 AM »
It varies from firm to firm, and depending on what you're designing!  You obvioulsy want working drawings, planning drawings will be much simpler).
A typical one I've seen would be along the lines of (taking housetypes one at a time):
/01 substrcture
/02 Ground Floor setting out
/03 Ground Floor services
/04 First floor joist layout
/05 First floor setting out
/06 First floor services
/07 Second floor joist layout
/08 Second Floor setting out
/09 Second FLoor services
/10 Roof plan
/11 elevations
/12
sections
dJE
dJE
