Author Topic: Dynamic Intelligent Leader !  (Read 181783 times)
Pad
Re: Dynamic Intelligent Leader !
« Reply #45 on: August 11, 2009, 11:33:59 AM »
Great
I can create the leader fine, but if I come to shift its position as in your example, the leader will move separately from the note, instead of as one.
It acts the same as a dissociated dimension or as if its been exploded.
Whether this is an incorrect setting within my acad 2005 (sorry previously I said 2004, its actually 2005) I wouldn't know.
Andrea
« Reply #46 on: August 13, 2009, 02:35:34 PM »
New release...
DILEADER v.1.6
(Dynamic Intelligent Leader)
what's new on this release ?
  • Textstyle follow DIMTXSTY variable
  • DILEDIT can now allow to select Leader and Text
  • Icon Added on mouse over a leader allowing user to see wich leader have been created by DiLEADER ( follow the GRIPSCOLOR variable)
  • Bug Fixed when Text was deleted from DiLeader object allow now to Edit Leader who do not Contain any Text or Mtext
  • Bug Fixed for 2005 when try to switch Text or Mtext option
tested on AutoCAD 2005, 2006 2007 2008 2009 and 2010.
Enjoy !  :-)
Keep smile...
Sebb77
« Reply #47 on: August 13, 2009, 02:48:56 PM »
Awesome work !  I'll test it more down the road and get back to U  if i find any bug. Thks for sharing again Andrea.
Your app name could as well apply to you. Dynamic and Intelligent leader.  :wink:
Andrea
« Reply #48 on: August 14, 2009, 08:37:32 AM »
LOL ! thanks.  :angel:
Keep smile...
GDF
« Reply #49 on: August 14, 2009, 02:26:49 PM »
Andrea
I still can not move the leader without breaking the link as per your illustration.
Also when I move the text, this link is also broken.
Only moving the object taged seems to keep the reactor link.
Andrea
« Reply #50 on: August 14, 2009, 02:46:37 PM »
Andrea
do you use DILEDIT command ?
Keep smile...
DEVITG
« Reply #51 on: August 15, 2009, 09:34:25 PM »
Nice and awesome.
Thanks for your effort.
GDF
« Reply #52 on: August 17, 2009, 02:54:17 PM »
Andrea
No. I didn't. That's pretty slick.
Andrea
« Reply #53 on: August 17, 2009, 06:01:22 PM »
Thanks...
there is the last release..
DiLEADER v.1.7
Some bug fixes and icon added when mouse cross over text entity.
 :wink:
Keep smile...
Andrea
« Reply #54 on: August 19, 2009, 02:47:35 PM »
There it is....like promised..
Another LAST release..  ;-)
DiLEADER v.1.8
New:
- DILA and DiLEADERA command added for Quick annotative Leader
- Modification entity remake to allow Annotative Leader and Text.
 :roll:
Keep smile...
Xander
« Reply #55 on: August 19, 2009, 10:16:22 PM »
Andrea,
WOW.  Why is it that AutoDesk couldn't come up with this feature.
While playing around with it in a new template everything works perfectly.  However, if I jump into one of my companys' standard I get the error 'Automation Error. Key not found' right after selecting the object.
I've skimmed through the code looking for that clause to see if your code princ'ed me the error with no luck.
Regards,
Xander
Andrea
« Reply #56 on: August 20, 2009, 09:52:50 AM »
Thanks Xander...
Few Questions...
- What release of AutoCAD ?
- What Kind of object you have selected ?
- Do you run any other routine maybe have conflict with ?
- is that happend on each file ?
Please let me know.
thanks.
Keep smile...
Xander
« Reply #57 on: August 20, 2009, 07:01:50 PM »
Andrea,
-Currently Running AutoCAD 2010
-Just a rectangle.
-We have many routines, but none which should be conflicting.
-Only happens on our company templates.  Every other template works.
I have come to think it has something to do with text styles.  I have attached an example to this post for your viewing pleasure.
Regards,
Xander
Andrea
« Reply #58 on: August 20, 2009, 08:50:37 PM »
Thank you....It is now fixed !  ;-)
it was the Arrow custom leader... ;-)
This fix will be add on the new release 1.9..(next week)
I've remake the reactor to allow user to edit object with the Propreties Panel.
and add some fix when copying Leader.
Thanks again.
Keep smile...
Xander
« Reply #59 on: August 20, 2009, 09:09:06 PM »
Thanks again.
No, thank-you for the development.  This has been a much needed feature inside AutoCAD for a loooooonnnnnng time.  I'm only glad I could help.
 :-D
