Author Topic: Hatch Pattern Not Found - How does it draw it then?  (Read 2468 times)
James Cannon
« on: June 09, 2009, 10:34:14 AM »
So you open a drawing from someone else.  They use a custom hatch, or a hatch that's just from some other program or vertical.
I open it on my machine without having the .pat file for that hatch.  Somehow Autocad still draws this hatch correctly.
How the heck does it draw the hatch, if I don't have the hatch pattern?  I thought it would be like having a text object with a font I don't have... it'd have to subsitute... but it doesn't- it draws the hatch properly.
That's -always- made me curious.
Matt__W
  • I like my water diluted.
Re: Hatch Pattern Not Found - How does it draw it then?
« Reply #1 on: June 09, 2009, 11:27:10 AM »
I've always thought of it being like a type of proxy object or an embedded shape file within the drawing.  Although I could be wrong.   :|
Autodesk Expert Elite
James Cannon
« Reply #2 on: June 09, 2009, 11:27:42 AM »
Better than what my guess was; magic compu-gnomes.
Matt__W
« Reply #3 on: June 09, 2009, 11:28:54 AM »
Are they related to the Travelocity gnome??   :lol:
M-dub
« Reply #4 on: June 09, 2009, 11:33:20 AM »
Is there an Alternate Hatch Pattern setting somewhere like there is for fonts?
If so, maybe their custom hatch pattern looks just like the one you have set as your alternate?
/stab in the dark
James Cannon
« Reply #5 on: June 09, 2009, 11:36:45 AM »
Nah, I don't have any custom hatches at all these days.  It's nothing I have.
M-dub
« Reply #6 on: June 09, 2009, 11:41:25 AM »
No, I was thinking that maybe they took one that's a standard issue hatch pattern and renamed it for whatever reason, but the one they renamed is also being used for your alternate pat... if the option to set an alternate even exists.
Still... it's just a wild guess.
« Reply #7 on: June 09, 2009, 12:12:00 PM »
IIRC, a hatch is just a special block. When you apply a hatch it creates a block with a name you won't find in the block table, but the original hatch pattern is tied to it. When you open the drawing it looks for that pattern, if found the hatch will be drawn according to that pattern's definition. If it isn't found, then the last "block" is used.
Matt__W
« Reply #8 on: June 09, 2009, 01:58:25 PM »
I just pictured a hatch pattern with a helmet and racing stickers.   :lol:
SDETERS
« Reply #9 on: June 09, 2009, 03:52:07 PM »
Per JEff_M's Comment I wonder if you modify the Boundary of the hatch if the hatch will automatically update.  Or will it just stay Like a block and not fill the space in completely?
Make sure you try this on a copy of the drawing not the good file.
hugha
« Reply #10 on: June 09, 2009, 08:01:50 PM »
The hatch definition is stored in the drawing.
You can use GETPAT ( www.turvill.com ) to extract it.
Similarly, HatchKit ( www.hatchkit.com.au)  can extract it from a DXF of the drawing or a drawing portion containing the hatch.
Hugh Adamson
Cadro Pty Ltd
www.cadro.com.au
