Author Topic: Floorplan  (Read 2024 times)
Conrad
Floorplan
« on: May 14, 2009, 01:26:03 PM »
Hello everyone I was wondering if anyone knows of a way that I could use an overall floorplan drawing and be able to select a certain area on that floorplan and have that area come up as an enlarged/detailed drawing. Is this something possible in AutoCAD?
Thanks in advance,
Conrad
M-dub
Re: Floorplan
« Reply #1 on: May 14, 2009, 01:29:42 PM »
What, like hyperlinks?
Re: Floorplan
« Reply #2 on: May 14, 2009, 01:34:53 PM »
Through viewports it is.
M-dub
Re: Floorplan
« Reply #3 on: May 14, 2009, 01:36:00 PM »
D'oh!
Yeah, I was thinking that the detail already existed as a separate drawing...
never mind.  :)
deegeecees
Re: Floorplan
« Reply #4 on: May 14, 2009, 01:39:37 PM »
I created something similar for plant managers, using links to dwf files. Basically, click on the product line, and that takes you to a close-up detail of that product line, then all components had their respective links to the detail drawings, etc. Is that what you're talking about?
Re: Floorplan
« Reply #5 on: May 14, 2009, 01:39:56 PM »
D'oh!
never mind.  :)
Sometimes the easy way isn't that visible.  The whole ' seeing the tree.... forest ' thing.
Conrad
Re: Floorplan
« Reply #6 on: May 18, 2009, 01:23:20 PM »
Sorry out in the field haven't had much time to check the computer. I believe what I am looking for is something similar to what DGCS posted. Also, is it possible to have it linked from one drawing to another drawing?. I appreciate the input I have gotten so far.
Matt__W
  • I like my water diluted.
Re: Floorplan
« Reply #7 on: May 18, 2009, 01:24:33 PM »
Thanks in advance,
Conrad
Revit!!
Autodesk Expert Elite
deegeecees
Re: Floorplan
« Reply #8 on: May 19, 2009, 10:35:41 AM »
Yes, set them all up as dwf's and go backwards to until you've reached the overall floorplan.
- Setup parts
- Setup sub-assemblies
- Setup assemblies
- Setup floor plan details
- Setup overall floor plan
The users would have to have the dwf viewer installed.
