Often there are maximum gradient constraints too.
I don't use the C3D grading tools often but can't you use a grading tool to have the alignment take on the elevations of the surface? Then lower it by 1.2m and proceed from there? Notice I don't know how to proceed from there.......
Now, how about a combination of a lot of things that have been put forth here:1. Draw polyline along the alignment2. Convert to feature line3. Get elevations from surface (insert grade break points)4. Weed feature line5. Lower the feature line distance x6. Create quick profile of the feature line (no need to profile any surface, just the feature line)7. Export profile to LandXML8. Import profile from LandXML
