The /b switch designates a script to run after AutoCAD starts. To invoke a script when you start AutoCAD, use the following syntax: acad [drawing file] /b script The script file must be listed after the /b switch on the command line; an SCR file type is assumed. If AutoCAD can't find the script file, it reports that it can't open the file.Scripts can be used to set up drawing parameters in a new drawing file. For example, the following command creates a new drawing called widget and runs the script called setup.scr:acad widget /b setup When the script has finished, the Command prompt is displayed.
i wanna a script to run on startup and I would like to be able to to have it run on everyone's machine without sitting down at each station and setting it up
