Ive looked at 60 or so lines so far and i have quite a few comments. All being that after 63 lines the code does nothing more then set and evaluate and reevaluate variables with no chance to alter those variables from the end user (so why evaluate and reevaluate if nothing can be changed?)
I only have a few minutes left on lunch so i will see how far i get. ...maybe we can do a re-write on this for ya.
Wow, that would be a GodSend if you could. I'm not that much of a programmer but can organize thoughts
on how to and by working my imagination come up with the what if and see if it works. This time it did but not
the right way for sure. I have seen hundreds of posts on this. Who knows maybe Autodesk will add it as a variable to
do a textmask offset that is global. I hope anyway, but till then this works a little bit. I highly respect the work
that was done by the original authors and hope they might want to take it to the next progression.
MJP
Mike
