Author Topic: Accessing C3D 2009 Parcels causing an exception error  (Read 2085 times)
surveyor_randy
« on: February 06, 2009, 09:14:51 AM »
I haven't worked with parcels yet in .NET and am trying to create a legal description writer.  Just trying to get my feet wet, I came up with the following code to access parcels and it is throwing an exception error: "Unable to cast COM object of type 'System.____ComObject' to interface type 'Autodesk.AECC.Interop.Land.AeccParcelSegment.......  No such interface supported."
For Each oParcel As AECC.Interop.Land.AeccParcel In m_oAeccDb.Sites.Item(0).Parcels
                For Each oParcelSegment As AECC.Interop.Land.AeccParcelSegment In oParcel.ParcelLoops
                    If TypeOf oParcelSegment Is AECC.Interop.Land.AeccParcelSegmentLine Then
                        Dim oLine As AECC.Interop.Land.AeccParcelSegmentLine = oParcelSegment
                        ed.WriteMessage(vbCrLf & "Distance = " & oLine.Length)
                    ElseIf TypeOf oParcelSegment Is AECC.Interop.Land.AeccParcelSegmentCurve Then
                        Dim oLine As AECC.Interop.Land.AeccParcelSegmentCurve = oParcelSegment
                        ed.WriteMessage(vbCrLf & "Radius = " & oLine.Radius)
                    End If
                Next
Next
I don't understand the error, could someone kindly give me a push in the right direction in what I am doing wrong to access parcels in this manner?  Thank you!
Jeff_M
  • C3D user & customizer
Re: Accessing C3D 2009 Parcels causing an exception error
« Reply #1 on: February 06, 2009, 10:36:11 AM »
Here's some quick code that does what you are trying in this example. Note the 2 big things, ParcelLoops can have more than 1 Loop so you need to specify which loop (I think that this will normally be 0, I haven't investigated why there would be more than 1..perhaps islands in the middle?), then you must get the ParcelSegmentElement.
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports Autodesk.AECC.Interop.Land
Imports Autodesk.AECC.Interop.UiLand
Imports mgdAcadApp = Autodesk.AutoCAD.ApplicationServices.Application
Public Class Class1
    <CommandMethod("TestMe")> _
     Public Sub TestMe()
        Dim m_AcadApp As AcadApplication
        Try
            m_AcadApp = Application.AcadApplication()
            Dim m_oAeccApp As New AeccApplication()
            m_oAeccApp.Init(m_AcadApp)
            Dim m_oAeccDoc As AeccDocument
            m_oAeccDoc = m_oAeccApp.ActiveDocument
            Dim ed As Editor
            ed = mgdAcadApp.DocumentManager.MdiActiveDocument.Editor
            Dim strSiteName As String = "Site2"
            Dim oParcels As AeccParcels = m_oAeccDoc.Sites.Item(strSiteName).Parcels
            Dim oparcel As AeccParcel
            For Each oparcel In oParcels
                For Each oParcelSegment As AeccParcelSegmentElement In oparcel.ParcelLoops(0)
                    If TypeOf oParcelSegment Is AeccParcelSegmentLine Then
                        Dim oLine As AeccParcelSegmentLine = oParcelSegment
                    ElseIf TypeOf oParcelSegment Is AeccParcelSegmentCurve Then
                        Dim oLine As AeccParcelSegmentCurve = oParcelSegment
                    End If
                Next
            Next
        Catch
            MsgBox(Err.Description() & Err.Number)
        End Try
exit_here:
End Class
Note that this is not great code...I throws some warning messages, but it works and is all I have time for right now.... Good luck!
surveyor_randy
« Reply #2 on: February 06, 2009, 10:54:23 AM »
Thanks for the sample Jeff!  I really appreciate it!  :-)
