Author Topic: IS THERE A WAY????  (Read 3314 times)
raresp
IS THERE A WAY????
« on: November 14, 2003, 10:24:34 AM »
Hi guys,
I have a question for LDD users. Let's say you have a polyline and 2 AECCpoints placed on it. (doesn't matter the positions(end, beggining...)). Is there a way to find the slope between those points but taking the length along pline between those points????. and then is there a way to insert a point between them (placed on the pline) to a certain distance from one of them. (taking that slope). All the lengths should be measured on the pline.
I know that there is an utility for that made by landproject.com...Point tools
But, can I do i without that???? is there a workaround or a tric???
thanks
raresp
IS THERE A WAY????
« Reply #1 on: November 14, 2003, 10:54:52 AM »
you're saying the points are on both ends of the pline, or just somewhere on it?
raresp
IS THERE A WAY????
« Reply #2 on: November 14, 2003, 10:59:06 AM »
just somewhere on it..
IS THERE A WAY????
« Reply #3 on: November 14, 2003, 11:01:53 AM »
I believe this can be done, let me try. be right back..................
raresp
IS THERE A WAY????
« Reply #4 on: November 14, 2003, 11:05:52 AM »
done with lisp or just simple LDD commands???? I'm trying as well :-)
IS THERE A WAY????
« Reply #5 on: November 14, 2003, 11:10:51 AM »
with LDD Point commands.
IS THERE A WAY????
« Reply #6 on: November 14, 2003, 11:34:06 AM »
what about Points -> create points interplote -> by relitive location
raresp
IS THERE A WAY????
« Reply #7 on: November 14, 2003, 11:39:21 AM »
this one will create a point on the straight distance between those 2 . and it might not be placed on my polyline. The slope is calculated with the horizontal straight distance between those 2 points. Not the distance on the pline between those 2 points..... Can I paste a GIF or BMP in this post... I want to show you... what I'm looking for...
raresp
IS THERE A WAY????
« Reply #8 on: November 14, 2003, 11:59:17 AM »
I just post a dwg in the pond
http://www.theswamp.org/lilly.pond/raresp/test_points.dwg
Check it to see what I'm looking for...
raresp
IS THERE A WAY????
« Reply #9 on: November 14, 2003, 12:41:07 PM »
Thanks a lot Mark. I got you....
IS THERE A WAY????
« Reply #10 on: November 14, 2003, 01:51:45 PM »
Did that work? and were did the dwg go?
raresp
IS THERE A WAY????
« Reply #11 on: November 14, 2003, 02:16:21 PM »
Yes it worked..... I thought that I should erase the dwg since your help worked. I can upload it back...
I didn't know all the options for that command.....
You save me a lot of time.
Since I know that you work with LDD (or LDT) a question for you. I'm doing a 3d presentation for a subdiviaion... All the roads are 3d polylines ( cl, eop, curbs, sidewalks...) to create my TIN.
Now the presentation is gonna be in 3ds Max or Autodesk Viz...what is your opinion should I generate the TIN as 3dface or Polyface Mesh. I understand that a Polyface mesh cannot have more than 30000 vertices?
Or is there a way to represent that TIN as you would represent it with 3D Grid from civil design (cross sections)???
Re: IS THERE A WAY????
« Reply #12 on: February 07, 2007, 01:14:16 PM »
I would use the 3d faces and import them into Max or Viz.
Then turn it into a mesh within that application and apply your materials as desired. I have done this where each surface material is on different layers, this make it easier to apply materials to the roads, sidewalks, trails, etc.
Most of this material assignment is now handled within Civil 3D by default.
