Author Topic: Determing AutoCAD install directory with Verticals present  (Read 6367 times)
wmtcadguy
« on: January 08, 2009, 02:45:49 PM »
I've written an add-on in .NET to be used in plain Jane vanilla AutoCAD only.  I've also written an installer to add some entries to the registry so that my add-on loads at start up, pretty simply and straight forward.  All goes well when AutoCAD is the only application installed, but when verticals are present my application ends up being installed under whatever vertical was installed last.  Sometimes this is AutoCAD and sometimes it's not.  Is there any sure fire way to tell (by reading registry keys) where the AutoCAD application lives in the registry?
Spike Wilbury
Re: Determing AutoCAD install directory with Verticals present
« Reply #1 on: January 08, 2009, 02:54:26 PM »
Have you look into:
DynamicLinker Class ?
And read about:
ProductKey
Per ObjectARX docs...
acrxProductKey();
This function returns the registry path for the version of AutoCAD currently (or most recently) loaded.
HTH
wmtcadguy
« Reply #2 on: January 08, 2009, 02:59:44 PM »
Yeah, that won't work for me.  Since C3D, ARCH, etc. are verticals to ACAD, which ever is loaded last is what acrxproductKey() returns.  I need to know where AutoCAD 200x is installed.  I'd like also not to have to update my installer everytime a new version of ACAD is rolled out.
sinc
« Reply #3 on: January 08, 2009, 03:24:35 PM »
Well, the install directory is stored in HKLM\SOFTWARE\Autodesk\AutoCAD\{release}\ACAD-{version}\AcadLocation.
You still need to update your installer for each version, though (at least, if your product is designed to work with the new version), because the registry key changes with every version of every product...
Spike Wilbury
« Reply #4 on: January 08, 2009, 03:43:32 PM »
I see....
Here is something that might help...
http://through-the-interface.typepad.com/through_the_interface/2006/09/automatic_loadi.html
Spike Wilbury
« Reply #5 on: January 08, 2009, 03:56:04 PM »
and this one
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=9120436&linkID=9240617
and use the above info to change the values of:
\\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\releaseNum\
    ACAD-ProductID:LocaleID\
KewlToyZ
« Reply #6 on: January 08, 2009, 04:08:18 PM »
%SystemDrive%\
wmtcadguy
« Reply #7 on: January 08, 2009, 05:09:41 PM »
LE,
Thanks.  Wasn't exactly what I was after but it leads me to believe what I really want is not possible due to the poor structure autodesk uses for their implementation of verticals.  :-(
Thanks for all your help.
sinc
« Reply #8 on: January 08, 2009, 05:31:55 PM »
I'm not sure where you're getting hung up, but it seems like you should be able to do what you want...
Maybe it's the sort of thing where you need to check during your application initialization and see if "IsPureAcadProfile" == 1 in the currently-loaded Profile, and if so, start your app?  Not sure when they added "IsPureAcadProfile" to the registry entry for each profile, but it's in 2007 (the earliest I currently have installed on my machine).
jmaeding
  • I'm just here for the Shelties.
« Reply #9 on: January 08, 2009, 05:43:30 PM »
Determining what acad's are installed and the paths should be easy.
Check out:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.2
or change the last number as desired (17.0, 17.1...)for the three versions within a series.
The items in that key are constant no matter what funny business the person who installed it did.
Like, Civil 3D is ACAD-7000:409, the others have similar numbers so you should always be able to check on any settings for a given flavor of acad.
James Maeding
wmtcadguy
« Reply #10 on: January 08, 2009, 06:35:54 PM »
Check out:
The problem is basically that the .NET deployment project doesn't allow you to view all the keys under a key.  You have to know what's there already.  By looking at the value of
\HKEY_CUR_USER\SOFTWARE\Autodesk\AutoCAD\CurVer
I can get the next Key (17.1 or 17.2 in my case) by looking at the value of the CurVer key under that key I can get the latest installed vertical's key (6001:409, 7004:409, etc.).  The problem I have with this is I'm trying to write an enterprise wide solution and the enterprise I'm writing it for is not level set.  Some users have 2008 some 2009, some use english, some use spanish, etc.
The .NET deployment project is not robust enough to do manipulations on Registry keys read otherwise it'd be a quick and easy.
Not to mention that everytime a new version of AutoCAD is put out to the enterprise somewhere I'll have to write a new installer.
I basically agreed to some impractical requirements before I knew the whole story.
MS and Autodesk need to come ask me about things like this before they run off and just do it.  :laugh:
KewlToyZ
« Reply #11 on: January 09, 2009, 01:27:35 PM »
Yeah it has presented a major problem for NVIDIA CAD specific driver installations, they only work for Vanilla AutoCAD none of the verticals
Jeff_M
  • C3D user & customizer
« Reply #12 on: January 09, 2009, 01:34:11 PM »
Odd, I just had my nVidia drivers ask me if I wanted to install the Autocad enhanced drivers for my newly installed Civil3D. They seem to work just fine....
KewlToyZ
« Reply #13 on: January 12, 2009, 06:55:01 PM »
Maybe they updated the thing finally after a year of my whining?  :ugly:
Jeff_M
« Reply #14 on: January 12, 2009, 07:25:12 PM »
Could be, these are the drivers dated Nov. 5, 2008
