and... read what they said in the "upgrade policy".... http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=8446637
Thanks everyone.Quick as ever.Reason for the question. Change of hardware. Transferring licences to new machine problems.
Quote from: Bob on January 07, 2009, 10:37:53 AMThanks everyone.Quick as ever.Reason for the question. Change of hardware. Transferring licences to new machine problems.as far I remember (well just 1-1/2 brain cell left, so...) - Before AutoCAD 2005 you must have a code that you can use, means you can installed an keep using it.In this place they still use autoCAD 2002 - BTW.
The problem is if the original code was lost by our outsourced IT function.
Quote from: Bob on January 07, 2009, 10:54:01 AMThe problem is if the original code was lost by our outsourced IT function.It generates an installation file (RegInfoACD.htmll) where the acad.exe is located....
Quote from: LE on January 07, 2009, 11:00:24 AMQuote from: Bob on January 07, 2009, 10:54:01 AMThe problem is if the original code was lost by our outsourced IT function.It generates an installation file (RegInfoACD.htmll) where the acad.exe is located....They also lost the machine!
