Author Topic: text to mtext  (Read 3030 times)
allanp
text to mtext
« on: October 02, 2004, 07:45:17 AM »
Noticed on autodesk website that there is a lisp routine for changing text to mtext within the express frolder in autocad 2004. I cant seem to find it can anyone help?
cheers
Allan
text to mtext
« Reply #1 on: October 02, 2004, 08:56:42 AM »
Load the expresstools into AutoCAD... at teh command line, you should be able to type Expresstools and/or menuload the Expresstools menu. The command is txt2mtxt or something like that...
text to mtext
« Reply #2 on: October 02, 2004, 08:58:17 AM »
I think if you install the express tools from the CD you don't need to load any menus, the setup  progrm will do it for you.
Dommy2Hotty
text to mtext
« Reply #3 on: October 04, 2004, 04:03:50 AM »
If you do need to load the menu (if you don't have the pulldown menu) the file you'll be looking for when using the "MENULOAD" command would be "ACETMAIN.MNU". Here is the path to mine...your username will be different...
C:\Documents and Settings\Dom\Application Data\Autodesk\AutoCAD 2004\R16.0\enu\Support
ML
text to mtext
« Reply #4 on: October 04, 2004, 07:12:16 PM »
Once you load Express Tools, you can type
txt2mtxt  at the command line and you are on
Great command!
PDJ
text to mtext
« Reply #5 on: October 05, 2004, 01:22:31 PM »
I converted mine to D2M.. Dtext 2 Mtext.. Use it all the time..
ML
text to mtext
« Reply #6 on: October 05, 2004, 06:40:32 PM »
Did you do that in your .pgp file P?
Accelerators are cool too
I have an accelerator to start the windows calculator from within AutoCAD
