Author Topic: menucmd troubles  (Read 1777 times)
jbuzbee
menucmd troubles
« on: November 14, 2008, 08:59:44 AM »
This should be easy, but I don't do much menu customizing.  :-(
Can someone please help with the following:
(progn (menucmd "P0=ACA.element_id=MnWindow")(menucmd "P0=*"))
I'm trying to pop up the "Window" pull-down menu.
Thanks.
James Buzbee
Windows 8
Crank
Re: menucmd troubles
« Reply #1 on: November 15, 2008, 07:40:41 AM »
I don't know what number your Window-pulldown has, but if it's for instance #10, you can use something like:
(menucmd "P10=*") Open menu #10
