Author Topic: Standard Graphical Scales  (Read 5105 times)
KewlToyZ
« on: November 10, 2008, 05:03:25 PM »
I'm sort of surprised AutoCAD doesn't seem to have these as blocks anywhere I know of.
Does anyone know where there may be a package of Architectural Graphical Scales for download.
Just thought I would ask before going to the trouble of making them.
Thanks :D
Spike Wilbury
Re: Standard Graphical Scales
« Reply #1 on: November 10, 2008, 05:56:24 PM »
Thanks :D
In the AutoCAD 2007 for example, open the file Annotation - Imperial.dwg (under the sample/dynamic blocks/ folder)
And in there there it is a DB with all the standard ones.
Spike Wilbury
« Reply #2 on: November 10, 2008, 06:05:14 PM »
Or see if these ones helps... (including architorture and the other ones)
Matt__W
  • I like my water diluted.
« Reply #3 on: November 11, 2008, 08:23:02 AM »
Thanks :D
The Content Browser (Ctrl+4) is a great tool.  Just fire it up, type in something to search for in the upper-left search box and click GO.  A list of insertable (insertable??) blocks, tools, parts, etc... is generated.  Just use the eye-dropper to drag and drop.
Autodesk Expert Elite
KewlToyZ
« Reply #4 on: November 11, 2008, 09:12:31 AM »
MEP 2009 only has the single 1/8"=1' scale in the entire content library.
KewlToyZ
« Reply #5 on: November 11, 2008, 05:10:48 PM »
Thanks for the help to all  ;-)
jonesy
  • SuperMod
« Reply #6 on: November 12, 2008, 02:04:06 AM »
Long shot, but is there anything here?
KewlToyZ
« Reply #7 on: November 12, 2008, 12:28:47 PM »
Not for the Scales but interesting block libraries.
I found the ones Esquivel linked were more than sufficient :)
Actually as far as our Standards are concerned I've bypassed use of AEC content.
File Auditing crashes and failures have been out of hand with AEC content throughout the 2007 file format.
Compatibility issues, cross platform issues, etc...
Not to mention file sizes increase more than the value it has posed to our uses.
It is a preference I haven't taken lightly but chose the simplest solution in not using them.
Thanks jonesy  ;-)
