FWIW, there IS a problem with the vertical link when you create a Surface. The "vertical", as we all know, in a TIN does not work. So the programmers built in a 0.002 offset for the vertical point. However, this offset is ALWAYS to the right of the section. So any Vert.links created on the left side will have the vertical offset closer to the centerline than the preceding point. This was discussed a year or two ago in the adesk discussion group, but the code remains the same today.
Michael, Christopher called it lazy. I call it "Why should I have to duplicate something the OP has already done, in order to help the OP?" If you don't see a problem in your attempt to duplicate it, that means you wasted valuable time to come to the conclusion it MAY not be a problem. But if you would label both of the top vertical segments you'd see where the deflection problem is.
