Author Topic: Double Drag behavior  (Read 3259 times)
mohnston
  • CAD Programmer
« on: August 19, 2008, 03:31:21 PM »
I've been using this jig class but have noticed a problem.
When I'm dragging the ent I get two ghost copies. One on my cursor and one at double the distance and direction from the start point of the drag to the current cursor point.
When I drop the ent it is fine. Only the ent on my cursor is placed on the drawing and it is where I picked. The double ghost thing is bugging me. Probably a logic problem but I don't see it.
I've tried to keep the class as simple as possible.
What might be causing this behavior?
public class JigEnt : DrawJig
        #region private member fields
        private Point3d previousCursorPosition;
        private Point3d currentCursorPosition;
        private Entity entityToDrag;
        #endregion
        Autodesk.AutoCAD.ApplicationServices.Document doc =
            acadApp.DocumentManager.MdiActiveDocument;
        public void DragEnt(
            ObjectId EntObjectID,
            Point3d StartPoint)
            try
                using (Transaction trans = doc.TransactionManager.StartTransaction())
                    // Assign the Entity based on the ObjectID provided
                    entityToDrag = (Entity)trans.GetObject(EntObjectID, OpenMode.ForWrite);
                    //Initialize cursor position
                    previousCursorPosition = StartPoint;
                    doc.Editor.Drag(this);
                    trans.Commit();
            catch (System.Exception)
        protected override SamplerStatus Sampler(JigPrompts prompts)
            //Get the current cursor position
            PromptPointResult userFeedback = prompts.AcquirePoint();
            currentCursorPosition = userFeedback.Value;
            if (CursorHasMoved())
                //Get the vector of the move
                Vector3d displacementVector = previousCursorPosition.GetVectorTo(currentCursorPosition);
                //Transform the ent to the new location
                entityToDrag.TransformBy(Matrix3d.Displacement(displacementVector));
                //Save the cursor position
                previousCursorPosition = currentCursorPosition;
                return SamplerStatus.OK;
            else
                return SamplerStatus.NoChange;
        protected override bool WorldDraw(WorldDraw draw)
            draw.Geometry.Draw(entityToDrag);
            return true;
        private bool CursorHasMoved()
            return !(currentCursorPosition == previousCursorPosition);
CAD Programming Solutions
Glenn R
Re: Double Drag behavior
« Reply #1 on: August 19, 2008, 03:39:36 PM »
At first scan, your CursorHasMoved function looks...wrong.
It should probably be:
return (currentCursorPosition != previousCursorPosition);
mohnston
  • CAD Programmer
« Reply #2 on: August 19, 2008, 04:14:06 PM »
I'm not sure if
(WrongnessOf(return !(currentCursorPosition == previousCursorPosition)
WrongnessOf(return (currentCursorPosition != previousCursorPosition)))
but making that change didn't change the behavior.
My mistake is probably much much dumber than that.
Glenn R
« Reply #3 on: August 19, 2008, 04:23:58 PM »
Like I said - scan ie quick.
I still think that judging by your method name, it should be as I suggested. I'll have to dig up some of my jig code to do a deeper analysis, but I'm tired and might do that tomorrow.
For others that may want to help, you haven't mentioned the following:
AutoCAD version
.NET Framework version
.NET Framework version being targeted (if applicable)
Visual Studio version
mohnston
  • CAD Programmer
« Reply #4 on: August 19, 2008, 05:02:06 PM »
I do appreciate your scan.
AutoCAD 2008
.NET framework 2.0 (using and targeted)
VS 2008 (framework 2.0 selected)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: August 20, 2008, 06:40:44 AM »
I’m using pretty much the same routine as you ( except my entity-to-drag is not database resident )
without any issues, you might try using a clone of your entity, then use the final coordinates of the jig to transform your original entity.
If that makes sense .
Glenn R
« Reply #6 on: August 20, 2008, 06:59:42 AM »
CloneMeForDragging or some such if memory serves....
