Author Topic: How would I model this?!?  (Read 7811 times)
Matt__W
  • I like my water diluted.
« on: August 06, 2008, 02:55:24 PM »
How would I go about modeling this octagonal canopy?
Any suggestions?  I haven't used the stock 3D tools (other than solid, union and subtract) so I'm not sure what's available.
Autodesk Expert Elite
jnieman
Re: How would I model this?!?
« Reply #1 on: August 06, 2008, 03:28:24 PM »
Obviously you only have to model one of the 8 triangles (if you're looking in plan view) at a time, and just array it to make the octagon.
I'd start with...
Draw a 3d poly that forms the 'entrance arch' I guess I'd call it... from the foot to the peak of arch, to the next foot.  Then drawn another arch at the next section...
ah screw it this is getting weird to explain and me no goot words much...
give me a minute and I'll upload an example
hint = loft 2d sections
jnieman
« Reply #2 on: August 06, 2008, 03:46:00 PM »
I copied it over as I did each step... and the profiles may be a bit different than in the picture, but the cool thing about loft is that you can alter the cross sections used for the lofted object, after it's lofted...
If desired, you can turn it into a solid using THICKEN command and entering a thickness.
However, I tried .25 and .01 and it failed... the cross section where it comes to a point is probably too small to allow it, so if you widen that line, you should be able to thicken it... I'll let you know if it let me.
jnieman
« Reply #3 on: August 06, 2008, 03:50:09 PM »
Yea, nevermind, I tried a few things and cannot get THICKEN to work.
I increased the end segment width (at peak) to 1/4" and tried thickening it at random values from .0001" to 12" and always gave me "Cannot thicken object with specified value"
May have to stick with surfaces, rather than solids.
Also, if you extrude a cylinder along the two "rails" where the tent poles go, it'll hide make it seem a little more realistic.
deegeecees
« Reply #4 on: August 06, 2008, 03:51:43 PM »
I'd use a mesh.
jnieman
« Reply #5 on: August 06, 2008, 04:04:29 PM »
This may get you started on that lamp post too...
Some reason, I couldn't get shell to work on the glass, so I copied the glass in place, scaled one by 0.95 then subtracted the smaller from the large... it's dirty and inaccurate, but it works for show and tell models.
Matt__W
« Reply #6 on: August 06, 2008, 04:19:47 PM »
For that canopy, how did you draw the arcs at an angle like that?
deegeecees
« Reply #7 on: August 06, 2008, 04:32:07 PM »
Thanks for the lesson Josh. Never used LOFT before, and with your examples in the pitched tent dwg, I see how you achieved what you did. I just lernt sumthin.
« Reply #8 on: August 06, 2008, 04:46:58 PM »
start in the nearest plane, draw an arc, then use 3drotate on it and chose a plane to rotate it in.
Spike Wilbury
« Reply #9 on: August 06, 2008, 05:03:21 PM »
Good one! Josh.
I am a neophyte in 3D if you ask me.... :)
Matt__W
« Reply #10 on: August 06, 2008, 05:06:11 PM »
That's all?  I thought/was hoping maybe there was some kind of fancy 3D modeling tool I could use.  I've never liked the 3D rotate command.
jnieman
« Reply #11 on: August 06, 2008, 05:47:38 PM »
actually I'm still stuck in my old-ass habits of changing the UCS... and using the regular rotate.
(normal)Rotate always rotates in the XY plane... so the AXIS of rotation is always parallel to the Z axis...
So for example, I modified the UCS so that the Z axis went through both "feet" of the first arc, then rotated it an arbitrary angle that looked right.
I used 3DRotate a few times but then would forget, lapse into my old habits, and I guess I never got used to it enough to use it regularly.
So whatever makes more sense to you, I guess.
No thanks needed... I'm glad to be of service whenever I can!  I get so much from y'all, it's nice to be on the other side of things for once :P
« Reply #12 on: August 07, 2008, 12:13:29 AM »
Try it now with all the helper glyphs ported from other apps, it's actually pretty likable these days.
More fun in an ISO view....
jnieman
« Reply #13 on: August 07, 2008, 08:54:19 AM »
Now if only the MATERIALMAP would use a base-point / end-point for the angle of rotation as well... the MATERIALMAP just makes you eye-ball it... and it's a poor-enough function that you can't get any precision out of it.  So if you need to rotate your brick pattern 90degrees, I always seem to end up just a BIT off over a long enough distance.... *thinks he should have started this with 'you know what really GRINDS my GEARS?*
« Reply #14 on: August 07, 2008, 10:39:19 AM »
Uh, how do you normally do your material UVW mapping there J-dawwg?
I do not recall having said challenge.
