Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
key for a distance
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: key for a distance (Read 2686 times)
vladimirzm
Guest
key for a distance
on:
July 24, 2008, 12:01:51 AM »
i have to type 0.15 and 0.25 many times and it would be nice if some key could do this, for example ctrl+1 for 0.15 and ctrl+2 for 0.25, this keys must work while a command is running specially with polar, otrack and osnaps references
line, clic for first point, move 90 degrees with polar and CTRL+1 (for 0.15), 3rd clic ...
Logged
Needs a day job
Re: key for a distance
Reply #1 on:
July 24, 2008, 12:11:09 AM »
What are you doing with these values?
Logged
vladimirzm
Guest
Reply #2 on:
July 24, 2008, 12:13:11 AM »
offset, move, copy, draw lines plines ...
Logged
alanjt
Needs a day job
Standby for witty remark...
WWW
Reply #3 on:
July 24, 2008, 12:16:57 AM »
you could easily do this as 'temporary key overrides' (i'm pretty sure that's the name). just make sure you remove the ^C^C from the beginning so it will stay in your active command.
Logged
Dropbox
vladimirzm
Guest
Reply #4 on:
July 24, 2008, 12:28:35 AM »
well i have tried but i don't get it work
Logged
vladimirzm
Guest
Reply #5 on:
July 24, 2008, 12:31:43 AM »
Quote from: ronjonp on July 24, 2008, 12:11:09 AM
i mean, here we usually build with bricks, and the standard is to draw walls with distances 0.10, 0.15, and 0.25 for every side of brick, then is very usefull pres one (or two) keys instead of three or four if you need this all the time.
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
WWW
Reply #6 on:
July 24, 2008, 01:24:31 AM »
Probably the easiest way is to add the values to your default RightClick Menu ... easy to do and maintain .. or it used to be
Logged
kdub in one timeline.
--> Donate to theSwamp<-
Global Moderator
Seagull
Reply #7 on:
July 24, 2008, 07:54:11 AM »
If you could be more specific there may be a custom lisp that would do the job.
A DWG with before and after examples would do nicely.
As for COMMANDs the 0.10 can be entered as .1 and 0.15 as .15
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
key for a distance
