Author Topic: MEP Questions  (Read 1285 times)
hudster
MEP Questions
« on: June 03, 2008, 07:21:14 AM »
I have a few questions if one of the MEP users can answer it would be great.
How easy is it to create a 3D building layout in MEP?
Does anyone use MEP with the IES VE plugin?
if so, how easy is it to export the 3D building model to another computer using IES?
Is it easy to draft, or do you have to design as you go?
How easy is it to export to the render package?
Can I still create 2D DWGs if I want to?
Does it still allow me to run a basic AutoCAD if I want?
Thanks for any replies.
Guest
Re: MEP Questions
« Reply #1 on: June 03, 2008, 08:29:52 AM »
It depends on the size of the building.  The hardest part is the initial setup (if you don't use what's in the box).  You could probably get away with using the default parts (you'd have to tweak the CTB file to plot the way you want to see things), we as a company, have decided to make a bunch of our own symbols - kind of a mix of industry standards and what they had when we were using Microstation (we switched from MS J to ABS 2 a few years back).
Never heard of it.  Do you have a link?
It depends on how "real" you want to make it.  A lot of our MEP users are just straight-up drafters who receive a redlined drawing and make the CAD drawing reflect the redline.  They don't worry about the Z-dimension too much.  As long as what's below gets hidden when an object above crosses it.  For example, if you were to look at some of our drawings in a 3D view you would see ductwork at 10' and 20'.  Obviously that isn't going to fit in a real building, but for most of the drawings we don't care just as long as we get a 2D representation of what's above and what's below.
We have a handful of younger guys (Jr. Designers) that are starting to embrace the system as a design tool and they are doing their drawings "real".  They are using exact locations, heights, etc... and making an actual real-world 3D model.
There is a command (_AecMassElementConvert) that will export the AECB objects to 3D solids.
Yes.  When you have MEP set to use a "plan" (top) view, then your drawings are essentially 2D, so yes, you can create 2D drawings.  As soon as you switch your view to a 3D or isometric view, then everything is viewed as 3-dimensional objects.  (See attached ZIP for short video demonstration).
Yes.  When you install MEP there is an option to create a link for basic AutoCAD.
You're welcome.  I hope this helps.
(Disclaimer: I am not an MEP engineer; just the lowly CADD Manager that set up everything for our company. :wink:)
hudster
Re: MEP Questions
« Reply #2 on: June 03, 2008, 08:53:29 AM »
http://www.iesve.com/content/default.asp?page=s98
here you go, it's a building analysis tool. In the UK we are required to do this by law for all new buildings
Guest
Re: MEP Questions
« Reply #3 on: June 03, 2008, 09:00:07 AM »
Revit MEP, huh?  We're not going to touch that for another year or so mainly due to the lack of content, but also because with some parts, when you (attempt to) connect ductwork to them, Revit doesn't automatically pick up with type of system it is or the type/dimensions of the ductwork.  It's a bit counter-productive.  We *are* however moving forward with Revit Structure.
Just to give you some idea of how old Revit is:
Revit Architecture was born November, 2002 (when Autodesk purchased Charles River Software)
Revit Structure was born June 7, 2005
Revit MEP was born April, 2006
Linkage
