I found a tip from a Frequent poster - Copy Excell Tables to AutoCad Tables.
The process is, copy your table from Excell, then in AutoCAD, do a Edit-Paste Special-AutoCAD Entities.
It works fine, but it also brings in the Cell 'garbage' from Excell.
I had one table that when brought into CAD, one column of the table's text was .05 - even though 'properties' showed it as .1. The way I found out was to explode the table, then look at the cells properties. It had some type of 'forumla' or
- like %/#%I or such - garbly gook to me.
The other thing I noticed is that it takes the numbers in the original table and shows them as '2.0000' instead of just '2'.
My intent of posting this is NOT to complain, but to ask if there is a way to bring it in without all of the formatting, so the table automatically switches to the Table Style that is loaded in the dwg.
Thanks in advance,
craigr
