Is there a way to plot just the linework in cadd to a jpg file without including the white background? I'm trying to overlay the linework onto an aerial w/o the white background....or is there a way in Photoshop to get rid of all of the white background without making the linework fuzzy?
No, not a JPG. JPG files do not support transparency, which is what you want.
I'm afraid that no matter what you do you'll get a bit of fuzziness to your linework due to the nature of raster files.
I'm not sure of your whole parameters/situation but...
What if you were to insert this aerial into Autocad, instead, behind your linework, and then printed it all at once to a JPG? That would be the best bet, imo.
If for any reason this is not an option, what you'd need is a graphics program that can edit the transparency of an image such as the GIMP or Photoshop or something along those lines. Plot to a regular iamge file (JPG, PNG, etc) then open it in the editor. Set the transparency color to whatever the background color is, and then the file will be transparent.... if WHITE is the transparent color, then anything white will become transparent. Then you have to save it as a file type that supports transparency (PNG, GIF, etc)
Of course when you bring this into Autocad, it will fail, now that I think of it. I don't think transparency comes through in Autocad.
