It took a bit over an hour to create the drawing with a surface from a DEM that looks like carp. It IS about 3' closer in elevation to real elevations than the GE surface (which is about 3' too high), but for a quick "here's how your site looks now", I'll stick with the GE surface that took just under 2 minutes to create.
Here's a pic of the 2 combined. The contour labels with the oval borders are from the GE surface, the others are from the DEM.
The whole key here is KNOWING that the GE surface is not accurate and using at a visualization tool only. Used in conjunction with the aerial image, it CAN be a useful tool. Another thing to bear in mind is that these images, and the associated DB's are only updated every 1-3 years (or more, depending on location).
