Author Topic: Match Attribute Height  (Read 1882 times)
Biscuits
« on: March 12, 2008, 01:51:56 PM »
Using Windows XP with Autocad2008.
I'm looking for a routine to select an attribute (to obtain text height)
then select other attributes to change their text height to match the previous selection.
Would appreciate any assistance with this.
Re: Match Attribute Height
« Reply #1 on: March 12, 2008, 01:55:29 PM »
Look at 'nentsel' to select the first attribute.  Then grab the Height property.  Then use the routine here to select the other attributes.
deegeecees
« Reply #2 on: March 12, 2008, 02:08:10 PM »
Need more?
(setq en1 (entget (car (nentsel))))
(setq en2 (cdr (assoc 40 en1)))
deegeecees
« Reply #3 on: March 13, 2008, 11:54:40 AM »
So, any progress?
Biscuits
« Reply #4 on: March 13, 2008, 12:25:12 PM »
Poor lsp skills and time constraints are my excuses for little progress for now.
Not sure how to combine your statements with T.Willey's
Thanks for your help
deegeecees
« Reply #5 on: March 13, 2008, 12:29:47 PM »
I'll see if I can whip something up for you then. I've got a little time.
deegeecees
« Reply #6 on: March 13, 2008, 12:53:08 PM »
My general disclaimer applies - "It aint pretty but it works"
There is a regen after each selection, and the variables aren't reset, but I've run out of time to make it a bit more friendly. Others here could probably do quite a bit better, but hey, it works.
Enjoy!
;match_att_ht.lsp
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;start prog
(defun c:match_att_ht ()
(setq cntr1 1)
(while (= 1 cntr1)
(setq ent1 (nentsel "\nSelect any text object <HIT ESC TO STOP>:" ))
(setq en1-2 (car ent1))
(setq en3 (entget (car Ent1)))
   (setq en3
                   (subst(cons 40 en2)
                         (assoc 40 en3)
                         en3))
        (entmod en3)
        (entupd en1-2)
(command "regen")
);;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;while
Biscuits
« Reply #7 on: March 13, 2008, 01:47:16 PM »
Lookin' purty to me!
Thank you.
Works great.
deegeecees
« Reply #8 on: March 13, 2008, 01:57:49 PM »
Not a problem (today anyway)!
