Author Topic: Lisp Example: Selection set to and from a list  (Read 8134 times)
« on: March 02, 2008, 10:09:25 AM »
Here is an example of creating a selection set, converting to to a list of entity names and then
converting the list of entity names back to a selection set.
(defun c:test (/ ss lst ss1)
  (and [color=green]; this will stop the lisp if any line below returns[/color] [color=red]nil[/color]
    (princ "\nSelect objects for the test.")
    (setq ss (ssget)) [color=green]; get user piciked selection set[/color]
    (princ (strcat "\nThere are " (itoa (sslength ss)) " items in selection set ss."))
    [color=green];;  convert a selection set to a list[/color]
    (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
    (princ (strcat "\nThere are " (itoa (length lst)) " items in the list lst."))
    (setq ss1 (ssadd))  [color=green]; create an empty selection set[/color]
    [color=green];;  add the items in a list to a selection set[/color]
    (mapcar '(lambda (x) (ssadd x ss1)) lst)
    (princ (strcat "\nThere are " (itoa (sslength ss1)) " items in selection set ss1."))
  (princ) [color=green]; keeps any unwanted comments from the command line[/color]
Referencing this post.
 http://www.theswamp.org/index.php?topic=10370.msg262481#msg262481
« Last Edit: March 02, 2008, 12:04:37 PM by CAB »
Re: Lisp Example: Selection set to and from a list
« Reply #1 on: March 02, 2008, 03:01:21 PM »
nice, I've never thought to try it like that :-)
gile
  • Marseille, France
« Reply #2 on: March 02, 2008, 03:40:02 PM »
Nice and concise but slower than iterative forms with repeat or while.
(defun test1 (ss)
(defun test2 (ss / n l)
  (repeat (setq n (sslength ss))
    (setq l (cons (ssname ss (setq n (1- n))) l))
(defun test3 (ss / n e l)
  (setq n -1)
  (while (setq e (ssname ss (setq n (1+ n))))
    (setq l (cons e l))
_$ (sslength ss)
275
_$ (benchmark '((test1 ss) (test2 ss) (test3 ss)))
Benchmarking ...............Elapsed milliseconds / relative speed for 4096 iteration(s):
    (TEST3 SS).....1156 / 5.34 <fastest>
    (TEST2 SS).....1687 / 3.66
    (TEST1 SS).....6172 / 1.00 <slowest>
« Reply #3 on: March 02, 2008, 08:02:43 PM »
Thanks gille, and yes I knew the fastest method.
I suspect it's because the method I posted iterates through the selection set once & then through the list to remove nil if it exist. So that two passes through the items selected.
I post that method most of the time because it so compact. I love compact. :)  Thanks kerry. 8-)
PS : http://www.theswamp.org/index.php?topic=14184.msg171131#msg171131
« Last Edit: March 02, 2008, 08:10:19 PM by CAB »
« Reply #4 on: March 02, 2008, 08:06:35 PM »
FYI: The performance penalty is 95% attributable to ssnamex. :)
« Reply #5 on: March 02, 2008, 08:34:39 PM »
Thanks Michael, that's good to know. :roll:
litss
« Reply #6 on: March 04, 2008, 12:23:22 AM »
Thx CAB for the example, it helps:)
To me, the way of "repeat" or "while" is much easier to understand. I always avoid using the "mapcar". It's too complicated. Every time I use it, I need to check it out in the "hlep".
« Reply #7 on: March 04, 2008, 09:53:46 AM »
OK, here it is without the Mapcar.
(defun c:test (/ ss lst ss1 i ent lst)
    (setq i -1)
    (while (setq ent (ssname ss (setq i (1+ i))))
      (setq lst (cons ent lst))
    (setq i -1)
    (while (setq ent (nth (setq i (1+ i)) lst))
      (ssadd ent ss1)
  (princ)[color=green] ; keeps any unwanted comments from the command line[/color]
litss
« Reply #8 on: March 04, 2008, 08:14:58 PM »
Wow, it is clear, I like that^_^
From this example, I can easily come to a conclusion that the "selection set" actrually is the same with the "list of entity names".
Look at this,
 (setq ent (ssname ss (setq i (1+ i))))___the "selection set"
 (setq ent (nth (setq i (1+ i)) lst))____the "list of entity names"
The "ent"s here are the same thing. They both represents the name of a entity.
The only difference is the way they are stored. One is stored in a list----(setq lst (cons ent lst)), the other one is stored in a set----(ssadd ent ss1).
Is that right?
« Reply #9 on: March 05, 2008, 12:01:24 AM »
You got it :-)
Note that ACAD limits the number of selection sets you can have so be sure and use private variable names or set then to nil when done.
