Author Topic: Reset Scale List  (Read 3019 times)
cadpro
Reset Scale List
« on: February 13, 2008, 02:00:31 AM »
Hi all,
Can we reset the scale list in ACAD 2008 using .NET?
Re: Reset Scale List
« Reply #1 on: February 13, 2008, 04:27:04 AM »
Yes :
From either the registry ,
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\<release>\<productKey>\Scale List
or
look at ;
 ... db.ObjectContextManager.GetContextCollection("ACDB_ANNOTATIONSCALES");
Then have a look at the AnnotationScale Class
Then the ObjectContextCollection.AddContext(ObjectContext annotationScale);
I don't have time to bash and test code tonight, so see how you go with those leads ...
It will probably just be 1/2 page of code, so be sure to post it back.
« Reply #2 on: February 16, 2008, 08:48:15 PM »
For anyone who thought about following up on this thread ...
        [CommandMethod("GetScaleList")]
        static public void getScaleList()
            Database db = HostApplicationServices.WorkingDatabase;
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            try
                ObjectContextManager oContextMan = db.ObjectContextManager;
                if (oContextMan != null)
                     ObjectContextCollection occ =
                        oContextMan.GetContextCollection("ACDB_ANNOTATIONSCALES");
                    if (occ != null)
                        foreach (AnnotationScale anScale in occ)
                            ed.WriteMessage("\n" + anScale.Name);
            catch (System.Exception ex)
                ed.WriteMessage(ex.ToString());
        [CommandMethod("AddScale")]
        static public void addScale()
            try
                    HostApplicationServices.WorkingDatabase.ObjectContextManager;
                    if (occ != null)
                        if (!(occ.HasContext("CadProSuperScale 1:14")))
                            // new scale
                            AnnotationScale annotationScale = new AnnotationScale();
                            annotationScale.Name = "CadProSuperScale 1:14";
                            annotationScale.PaperUnits = 1;
                            annotationScale.DrawingUnits = 14;
                            //add to context collection
                            occ.AddContext(annotationScale);
                AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString());
Piccys added :
« Reply #3 on: February 16, 2008, 10:06:24 PM »
... and to clear the list , except for the currently active scale ..
        [CommandMethod("ClearScaleList")]
        static public void ClearScaleList()
            try
                    if (occ != null)
                            if (!(occ.CurrentContext.Name.Equals(anScale.Name)))
                                ed.WriteMessage("\n" + anScale.Name + " : removed");
                                occ.RemoveContext(anScale.Name);
« Reply #4 on: February 16, 2008, 10:26:14 PM »
just noticed the Output pane in the debugger ..
after running the _SCALELISTEDIT command in AutoCAD
The thread 0x17ac has exited with code 0 (0x0).
'acad.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualStudio.Debugger.Runtime\9.0.0.0.....................
'acad.exe' (Managed): Loaded 'C:\ACAD2008\AcScaleList.dll'
'acad.exe' (Managed): Loaded 'C:\ACAD2008\en-US\AcScaleList.resources.dll'
The program '[5116] acad.exe: Managed' has exited with code 0 (0x0).
The function is defined in a NET assembly,
So it may be worthwhile having a look at the dll with Reflection.
I don't have time to look at the moment, so it's gone on the to-do list :-)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: February 16, 2008, 11:43:56 PM »
Wow! That sure is nice Kerry! I can use this  :kewl:
